Old 04-08-2017, 09:30 AM
smash smash is offline
It's all about risk mitigation. You can promise to be diligent and use extreme care and you may be lucky and finish the project with out anything bad happening. But consider the odds...
http://www.smashsrv-14build.com
Old 04-08-2017, 10:26 AM
kentlik's Avatar
kentlik kentlik is offline
I use these deals, they work well and come in many sizes. For the large bolts, I have used McMaster Carr stackable trays.
I like clear-tainers and they typically don't spill...
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 04-08-2017, 01:32 PM
The FIRST thing to do is check inventory. I put my hardware into the slider bins after labeling them with the part numbers. I put the rivets into empty plastic water bottles.
So far, in the 3,000+ hours and 4 years I've been building my slow-build RV-3B, I haven't had a single problem with this system. I've dropped the rivet bottles a couple times but never lost a rivet.
There are other successful storage systems described in the archives.
Incidentally, reducing the pixel size to 800 pixels wide makes the thread a lot easier to read.
Old 04-08-2017, 01:36 PM
n982sx n982sx is offline
You can also use a hybrid approach. Like my first plane build, where I had to procure all the hardware, I used the Harbor Freight trays for all standard AN hardware. No reason or need to go to the inventory sheet for those things.
Things that are a less generic or unique, stay in bags. I have far fewer bags to keep track of and I have one box for each kits inventory. Easy to grab the right box and use the inventory sheet to find what I'm looking for.
I also used them for all rivets and have had one minor sort needed. Turns out that they are not that hard to sort. Had it straightened out in minutes. A nastier spill would have taken longer but it has been easy to avoid. I always keep them closed and snapped shut between access. They hardly ever sit open so they have been jostled many times with no mixing problems.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 04-09-2017, 03:04 PM
challinan challinan is offline
I use Smash's method. Have the inventory sheet handy nearby, bags in the bins mounted to the back of my bench/wall. Works great for me. Haven't found anything missing yet (except time to work on it )
Chris
Chris Hallinan
Punta Gorda, FL
RV-14A (N914CH Reserved)
* (VS, Rudder, HS complete, elevators in progress)
* Donated for 2016, 2017
Old 04-10-2017, 11:05 AM
caapt caapt is offline
Default lost weekend of building
Don't give up building days. There's always something else to work on. Look ahead to the next chapter, the first few pages usually involve new parts to assemble and or fabricate. Debur parts or sheets. Prime parts. Cut out jigs.
Same thing while you wait for pro seal or epoxy resin to dry. Wish I had learned this earlier. Would have saved some money on 2nd day air charges.
14A Wing Complete!
Tail Complete
Fuse Complete
Engine installed
Old 04-10-2017, 01:33 PM
rapid_ascent rapid_ascent is offline
I bought the Harbor Freight bins since they have individual bins that can be removed from the larger container. That way if I knock one over its not a sorting problem.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
