Old 04-04-2017, 01:05 PM
Iluke Iluke is offline
Default Slider build order - final stages?
For those of you who have built a slider (mine is an RV-7), I have a question..
Can i delay riveting the forward top fuselage skin until the last minute? Specifically, can I fit the windscreen and canopy with the forward top skin in clekos? I know I won't be able to permanently install the windscreen or glass the windscreen fairing, but can I fit the sliding part of the canopy and all that stuff aft before riveting the final skin?
Reason being I'd really like to delay commuting to avionics until the VERY last moment possible...
thanks
Ivan
Ivan Luke
Hope Valley, RI
RV-7 SB
In the finish kit phase
2018 dues paid
Old 04-04-2017, 04:01 PM
Raymo's Avatar
Raymo Raymo is offline
I think you could do a rough finish of both but things will change slightly once the front top skin is riveted. Plus, you won't be able to install some clekos that will need to hold the skin down to fit the windshield.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 04-05-2017, 03:17 AM
tgmillso tgmillso is online now
Hi Ivan,
I am midway through the stage you mention in your build. I too didn't want to commit on avionics right yet, nor did I want to make forward access panels in the top skin like some do. Thus the way I tackled it was to purchase some avionics trays from Steinair (they will sell them separately, and are quite inexpensive for all but the Garmin GTN navigators). Using these, along with the measurements in the G3X manual, I cut the holes in the panel and sub-panel, and made associated doublers and mounting brackets. I also drilled holes on F-7107 forward fuselage ribs for mounting the engine monitor, transponder and other remote mounted components. Thus, I have very little invested at this stage in avionics, and things can change avionics wise (as they are very quickly) and you can still swap most items with what you currently have because the tray spacings are quite consistent.
You can then rivet the forward fuselage and mount your windscreen, but still make avionics installation relatively(??) easily at a later date. I have already completed my sliding canopy as this can be done at any stage (you will have to remove a few clecoes from the forward skin to get the canopy in place for the early fitting). All I can say is don't cut and drill the WD-643-SS roll bar brace until AFTER you have completed the bending and installation of the canopy, as my canopy frame was canted aft to a level that I couldn't fully rectify, thus I have had to cant my rollbar aft also, so I needed to purchase and re-cut/drill a new brace. Good luck.
Regards,
Tom.
Old 04-07-2017, 08:12 AM
Tom
Thanks very much! Some good suggestions.
R
Ivan
Ivan Luke
Hope Valley, RI
RV-7 SB
2018 dues paid
Old 04-07-2017, 08:40 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Yep
thanks
Ivan
That is exactly what I did - no problems when I eventually finished everything up.
Dan Langhout
2018 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
311 hours and counting . . . .
Now based at Moontown (3M5)
