Old 04-02-2017, 10:45 PM
gossend gossend is offline
Question Nord-Lock washers
Anyone consider using Nord-Locks on the main landing gear attach bolts? You know, the bolts you check every year and find them slightly undertorqued - again? Guarantee the Nord-Locks will fix it!
Given the peak stresses seen at touchdown, I'd even consider their new X-series washers. They would handle the momentary bolt stretch on the front-most bolts. Check out the videos on the Nord-Lock site - They'll make a believer out of you!
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with G3x Touch
Old 04-03-2017, 12:48 AM
hufise hufise is offline
Default Nordlock
Hi
Then washers are super against vibrating, I used it on the four engine mounts.
But Sensenich doesn't know the system. Because the bolt reduce part on the engine is a washer. A turning part !
Hello from Switzerland
Daniel RV -12 #120383 330 hrs
Old 04-03-2017, 07:12 AM
snopercod's Avatar
Default Nord-Locks are great!
I use 1/4" Nord-Locks to hold my brake discs to the wheels, with the approval of Matco. I also use 7/16" Nord-Locks to hold my 4" prop extension to the crankshaft with my own approval
(2018 dues paid)
Old 04-03-2017, 10:56 AM
Since installing the landing gear modifications in 2013 my landing gear bolts have not loosened at all, and I don't use Nord lock washers.
Old 04-03-2017, 10:19 PM
Default Nord-locks
Good to hear that. About how many hours have you put on the airplane; and more importantly, roughly how many landings. And is that mostly on dirt, grass, or pavement?
Dick Gossen
gossend@gmail.com
Old 04-04-2017, 12:56 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
No Nord-Locks. Torque still the same (just did my maintenance).
160 hours. 200 landings. 50% grass/pavement.
PH-BZT
MyKitlog
Picasa pictures
Old 04-05-2017, 11:46 AM
rongawer's Avatar
rongawer rongawer is offline
Default UL Power
UL uses N-L washers throughout their engines and they work great. They are little pricey compared to a common lockwasher, but when you absolutely want to be sure that the bolt is locked in place and don't want to use red loctite, they're great.
Ron Gawer
- RV12, N975G, SN 120840, All done with construction ...kinda. Next step is moving to the airport.
- BE58, N1975G, stimulating the economy one flight at a time.
Old 04-05-2017, 11:50 AM
rongawer's Avatar
Talking
Originally Posted by hufise View Post
Hi
While I applaud the use of N-L washers on your engine mount, I hope you also used cotter-pins. They're great lock washers, but pins are the bulletproof retainers I'd recommend for critical items such as your engine mount; use both and have the "belt and suspenders" approach. Nothing like a military grade nuclear option
Ron Gawer
