Old 04-01-2017, 01:41 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Default What Avex rivets are used on the -12?
Looking to use Avex on another airplane, and want to get the good stuff. So what part numbers are used?
Thanks!
Ed
RV-8 (steam gauges), RV-9A at KSAV (Savannah, GA; dual screen G3X with autopilot, GTN 650)
Previously RV-4, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2018 dues paid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 04-01-2017, 03:11 PM
90 percent of rivets are LP4-3.
Where extra strength is needed, the following rivets are used:
CR3213-4-02 CHERRY RIVET
CR3213-4-5
Joe Gores
RV-12 Flying
Old 04-01-2017, 03:31 PM
gossend gossend is offline
Default AVEX Rivets
Hi Ed! Long time!
Try Byler Rivets - a dealer Ph (972) 986-6792.
OBTW, I just sold that Glasair III you wrote about 25 years ago!
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with G3x Touch
Old 04-01-2017, 05:04 PM
I was looking for a part number like 01604-00414. I don't know how to decipher those numbers for details, but I suspect that LP4-3 only specifies the size... And I'm not able to dimple, so I'm looking for plain heads.
2018 dues paid
Old 04-01-2017, 06:43 PM
This might help. I don't know vendor PN's...
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 350
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 04-01-2017, 06:51 PM
SR2500 SR2500 is offline
Default AVEX Rivets
Go to the Aircraft Spruce Website and search for AVEX Rivets. They will be listed as AVEX non-structural rivets. Disregard the non-structural part of the description, I'm still baffled why they do that. They have a chart that lists all the grip lengths etc. PM if you have any questions, as I'm quite familiar with them.
Best,
Jerry Folkerts
Jerry Folkerts
Pietenpol, built and sold
Cygnet SF-2A, built and flying
Murphy Super Rebel, building
Vans, next build
Old 04-01-2017, 09:41 PM
John-G John-G is offline
Ed,
The rivets supplied by Van's for my RV-12 are NOT Avrex .... they are manufactured by Gesipa and are part number GSDM41-43APG. In the RV-12 plans, Van's refers to these rivets as LP4-3 rivets. The rivets are from Gesipa's series of rivets called Polygrip Multigrip blind rivets. It is an aluminum rivet with a steel mandrel that has a grip range from .039" -.197". Specifications for minimum strength are a shear of 162 lbs and tensile of 236 lbs.
The photo below shows the box of rivets Van's supplied with the RV-12 kit on the left. Also in the photo on the right are the flush rivets I purchased from Gesipa that were used to build my RV-12 (yes, I built E-AB) ... the flush rivets have the same tensile and shear strength as the low dome rivets from Van's and the part number is the same except the D is changed to a C for the countersunk version (the D is for low dome).
Hope this helps you.
Happy building,
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 04-02-2017, 06:53 AM
Ed -
Forgot to mention Gesipa has a minimum order of 10,000 and would not sell retail. I asked for and was given the name of a distributor in my area which subsequently ordered the rivets I needed for the external surfaces on the RV-12 project. (The RV-12 needed over 9,000 rivets because I went into the 10th box of 1,000).
Happy building,
John
www.dogaviation.com
Now Flying!!
