Old 03-31-2017, 02:01 PM
Djgeib Djgeib is offline
Default Temp probe location
Expecting my wing kit soon and am planning what items need to be installed in the wings. Going with a heated / AOA pitot probe. Was wondering where people have been installing temperature probes for ADAHRS in -8
Doug Geib
KFHB
RV8 empennage complete
QB wings started
Old 03-31-2017, 03:08 PM
flyinga flyinga is offline
I put mine in the NACA duct under the right wing.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 04-01-2017, 09:59 AM
SuperCubDriver SuperCubDriver is offline
Mine is on the inboard access cover. In the shade and out of cooling air and exhaust gases. I thought there is one more advantage: Replace the cover and no extra holes in the plane in case it will be removed one day or relocated.
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8, IO-375, P-Mags, 74RV Prop, flight testing
Old 04-02-2017, 01:01 AM
schmitty340 schmitty340 is offline
Under the left horizontal stab. also in the shade and out of sight. My AHARS is mounted mid fuse and the probe plugs directly into the AHARS unit, so nice short direct wire run. works great.
to be clear..Its mounted into the fuselage aft of the data plate under the horizontal stab.
RV-8 N8782D--Flying
Dues Paid
Old 04-02-2017, 08:31 AM
Default Left wing.
We found that we had just the right amount of wire with the probe to place in the left wing lower skin just to the inside of the first inspection cover, then run the wire up to the panel with no splicing of the wire. By putting the probe there it is in the shade of the wing somewhat in the medal from the leading edge to the trailing edge. Far enough away from the engine and prop slip stream so as to be in fresh un heated air and directly into the air stream to get as good a temp. reading as was allowed. What works for us may not work for you as there are a lot of panel set-ups out there and you need to think through you system and it's style and your needs and wants.
Hope this helps, yours, R.E.A. III #80888
Old 04-02-2017, 05:23 PM
Thanks for the advice. Think I'll be mounting 2 as I want 2 ADAHRS.
Doug Geib
KFHB
QB wings started
Old 04-02-2017, 08:48 PM
scsmith scsmith is offline
Plus one for inboard wing inspection cover. Aft fuselage under stabilizer may get artificial heating from exhaust. May be attitude/speed/rpm-dependent.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 470 in 8 years
also LS-6-15/18 sailplane
VAF donation Dec 2017
Old 04-03-2017, 05:37 PM
n82rb's Avatar
n82rb n82rb is offline
i talked to the guy that did most of dynons test flying and he had three different probes on his RV. he suggested on the fuse under the stab. thats where I put mine and it is not affected by exhaust.
bob burns
RV-4 N82RB
Old 04-03-2017, 10:41 PM
dalane4@yahoo.com dalane4@yahoo.com is offline
Default Temp probe
I voted for the right inboard under wing inspection panel. Short wire run, no prop wash, no exhaust, out of the sun and easy to access.
Old 04-07-2017, 10:44 AM
Wiley Wiley is offline
Put mine just behind the pitot mast.
Eric Wiley
RV-8 finished 9/15
Flying S Air Ranch (10XS)
Brownwood TX
