Old 03-27-2017, 02:59 PM
goatflieg's Avatar
Default RV-8 NACA ducts: Screens?
I'm thinking about installing my NACA ductwork in my QB wing, and this seems to be another potential pitfall for novice builders such as myself. No mention in the builder's manual, and the instructions that come with the duct kit are purposefully vague. I'm wondering if anyone has installed screens in the inlet of the duct? I know bugs aren't an issue at altitude... but I'm leery of having an unscreened opening that accesses the fuselage. I'm wondering if any other builders have thought of this, and what they might have done.
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2018... extra payment included for psychological therapeutic services rendered.
_______________________
Old 03-27-2017, 03:24 PM
DanH's Avatar
DanH DanH is offline
Study the plans carefully. A lot of builders miss the snake guard.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-27-2017, 03:42 PM
bret's Avatar
bret bret is offline
Snakes on a plane? are you kidding us or no? please tell us the story Dan.
2018 gladly supported
Old 03-27-2017, 04:17 PM
airguy's Avatar
airguy airguy is offline
That's what hangar cats are for...
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 03-27-2017, 05:54 PM
brad walton brad walton is offline
I put a stainless screen in my air vent systems, front and rear. Not at the NACA inlet opening, but at the SCAT tube connection on the front inlet and just below the eyeball vent in the rear. No univited bugs coming in through the fresh air vents.
And BTW I've hit bugs at 12k ft altitude
Old 03-27-2017, 06:22 PM
fl-mike's Avatar
fl-mike fl-mike is offline
I used a piece of honeycomb aluminum I had on hand from an EMI fan grill. 1/8" holes, about 1/2" thick. Cut it slightly oversize on the bandsaw, pushed it in, and secured it with some RTV or proseal. Kinda cool and works great. You can pick up small pieces on eBay.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 03-27-2017, 06:26 PM
N941WR's Avatar
N941WR N941WR is offline
Yes but first you have to get the correct RV ducting.
I used some screen material from an old sliding door my dog went through and then captured it at the NACA duct with the RV hose pictured above.
(Click to enlarge)
To secure the NACA duct to the inside of the fuselage, I used Pro-seal. Almost 10 years later, I haven't had an issue with the screening or the ducts.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-27-2017, 07:10 PM
BillL BillL is offline
Default Just did this 3 days ago.
Not an 8, but I just formed a cup of aluminum screen over 1 1/2" ID PCV and the cup fit perfectly inside the scat tube, secured it with RTV (X2).
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 03-27-2017, 07:16 PM
moosepileit moosepileit is offline
Stuff in a plastic sink strainer ball.
RV-6 N91GG, bought from builder.
O-320, slider, carb, mags, FP
Old 03-27-2017, 07:54 PM
Rv3Dave Rv3Dave is offline
Years ago, one summer day flight in my 8 I am getting sand blowing in my face. I think, that's strange, it is coming out of the vent and I am at high altitude, how can this be. Back on the ground I find a big mud dobber nest in the scat tubing, no screens. My solution was to cut some foam rubber plugs for the vents that I installed after each flight just like I habitually install a pitot cover. On a new build, I think screens would be a good idea.
