Old 03-26-2017, 07:28 PM
JDA_BTR JDA_BTR is offline
Default Control Grips
Saw the Tosten stick/grip combo for sale. I have the stick with no grip currently.
Can we list the possibilities?
1. http://www.tostenmfg.com/product-cat...ircraft-grips/
2. http://www.aircraftcontrolgrips.com/page1
3. Tons here: http://www.aircraftspruce.com/menus/...stolstick.html
N1463 seems a good number....
Old 03-26-2017, 08:50 PM
Jake14 Jake14 is offline
the standard Van's grips are cheap and very comfortable..
Old 03-27-2017, 01:07 AM
N62XS N62XS is offline
Default Tosten
I've now owned 3 sets of the Tosten -8 models. 100% reliable and very comfortable in use. You can't go wrong there.
IHN,
2017 Dues Paid
Robby Knox
"If it is to be, it is up to me" Thomas Smith
Old 03-27-2017, 06:30 AM
Walt's Avatar
Walt Walt is offline
I recently installed this one in my own aircraft from Composites International in NZ. It comes only with a PTT switch and you have to add the trim and buttons as required. I like that they use Otto trim and push button switches. I plan on keeping a few in stock for customers panels. After you add the switches these are not the least expensive grips you will find but the quality is very high. All said and done about $400+ ea.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 03-27-2017, 05:16 PM
Gahannaflyer Gahannaflyer is offline
I don't know if any of you have noticed. But the wiring on th CS8 grip is not what you expect for th 14. Don't do what I did. Duh, I figured I would wire violet to violet, yellow to yellow, blue to blue, etc. if you will notice on AFS's website documentation the wiring has been changed. AFS had to correct it because Tosten didn't align the colors like anyone would expect. Maybe Tosten has corrected the colors again by now. Who knows. But be careful not to get this screwed up. The pins that go in the molex connector are tiny and are a real pain to get out of the plug block. Proceed with caution!
