Old 03-26-2017, 04:18 PM
RepmikeBrown RepmikeBrown is offline
Default Trutrak servo mount
Does anyone have plans on servo mounts and placement on a 4
For a Trutrak autopilot
RV4 UnderConst
repmikebrown@yahoo.com
Mike Brown
Old 03-26-2017, 05:56 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Available on Trutrak website
All of the installation instructions ----- just completed a -4 install a week ago.
Have fun in the tail cone!
Ron
RV-10 Co-built (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV)
IO360, 180HP/CS, AFS 5600T, G650, VIZ385
Very Happy Contributor
Based at KCLW (Clearwater, FL)
Old 03-26-2017, 06:13 PM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
I just installed a trutrak serve last week. I chose not to drill out the existing rivets. I made a mount that sandwiched to the outside of the mounts, and held the servo about an inch further back. It works very well.
Here is a pic that I used to model. This isn't mine, but mine looks very similar.
I did a 230 mile flight in partial IFR. It worked perfect. Trutrak makes a nice product.
https://drive.google.com/open?id=0B7...XprTzc2Y0l3Rmc
RV-4 (not the builder)
0-320 (160HP) Sensenich Metal Prop
N617TN
Old 03-26-2017, 09:15 PM
Default Thanks
Todd, thanks for the info. If I understand correctly you didn't drill out and replace the top angles that are currently on the bell crank in the tunnel. Did you just use straight flats on the sides as the pic shows?
RV4 UnderConst
Mike Brown
Old 03-27-2017, 02:16 PM
Xkuzme1's Avatar
I used two pieces on the outsides of the pre-existing mounts. I started by using hack saw blades as the size shape to make the arms. I used .040 for my mounts. That worked well but there was a little lateral movement. I made the mounts again, but made them slightly taller with a small 90 bend in the bottom. They fit right into the elbow of the existing bell crank mount.
So basically this exact picture, with the arms sporting a 90 bend extending out 1/8 inch.
N617TN
Old 03-27-2017, 06:37 PM
Wolfpack3 Wolfpack3 is offline
Default roll servo mount
Here's what I did for the roll mount. I hope this picture is posted...
Old 03-27-2017, 10:31 PM
Default Roll
Thanks for the pic Todd R. I really like the mount better than what trutrak has on their drawings.
RV4 UnderConst
Mike Brown
