Old 03-27-2017, 01:24 PM
smash smash is offline
Default Starter Contacter orientation
I just attended the SportAir class on electrical systems and the instructor advised against orienting the starter motor contactor vertically (as shown in picture below). The g-forces of aerobatics can cause the contactor to close thus engaging the starter uncommanded. He advised to mount it 90 degrees to vertical. How are others mounting their starter contactors?
http://www.smashsrv-14build.com
Old 03-27-2017, 01:44 PM
rv8ch rv8ch is offline
Default starter contactor orientation
This seems to be an "old wives tale" according to Bob:
http://forums.matronics.com/viewtopi...065c2bd53a61d6
Originally Posted by bob nuckolls
I have yet to put my hands on any
failure of hardware that supports any notion of risk
due to airframe induced g-loads.
Mickey Coggins
http://rv8.ch
n982sx n982sx is offline
First, neither of those are starter contactors. They are both continuous duty contactors, in this case, for ground power and bus cross feed. They are not part of the kit and Van's has no responsibility for them.
Second, for what it's worth, the starter contactor supplied by Van's in the firewall forward kit mounts at about a 45 angle.
I have no knowledge about the efficacy of the SportAir workshop remark.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 03-27-2017, 01:56 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
I also took the sport air workshop with Smash and found it curious that the -14 has its start/master solenoids mounted at the 45 deg. I might have to call Vans to ask their thoughts on the subject.
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 06-20-2017, 11:58 AM
Erimo's Avatar
Erimo Erimo is offline
Default Relays clocking
So, did you have Van's answer ?
Old 06-20-2017, 12:47 PM
I don't agree with Bob's analysis since it is clear that he doesn't know which way the plunger of the contactor is moving relative to the vertical axis of an airplane if the brackets are mounted flush to a firewall ( In this configuration, the plunger could never be aligned with the longitudinal axis).
He also mentions looking at hundreds of T.C. aircraft...... I wonder how many of them were approved to purposely be experiencing 6+ g's during flight on a regular basis.
The contactors are mounted at 45* on the RV-14 because it is convenient for structural reasons and that then largely takes care of any possible issue as a result of pos. or neg G's.
BTW, there is nothing wrong with mounting the start contactor with the plunger vertical as long as you know which way the plunger moves, you mount it so it can only be influenced by neg. G's, and then you avoid high neg G's (likely 99.9% of all RV owners do).
Scott McDaniels
Hubbard, Oregon
Old 06-20-2017, 03:21 PM
Easy to prove or disprove. Weigh the plunger. Measure the force required to overcome spring force to close the contacts, if oriented that way. Compare.
If oriented the other way, measure the force required to open the contacts against force applied by the coil while it's active. Compare.
While I don't know this with certainty, I suspect that Bob's done that.
Charlie
