Old 03-24-2017, 03:19 PM
Kyle Boatright Kyle Boatright is online now
Default Planearound Door Guide Block Question
Any thoughts on how to shave the delrin guide blocks Planearound supplies with their latch kit? I need to shave 1/32 or maybe 1/16" from the guide blocks that mount to the doors. I understand that you want a tight fit between the door and cabin blocks to eliminate fore/aft slop in the latched doors, but right now, the doors won't close.
The other issue is how to shave them evenly while creating a presentable surface. A belt sander probably isn't the answer and I can't think of a safe way to do it with a tablesaw, router, jointer, or any of the other finger removal devices at my disposal.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 03-24-2017, 04:02 PM
ERushing's Avatar
ERushing ERushing is offline
I'm using a belt-sander. A timely question because I'm doing it this weekend. Once I get it nice and close, I may build up a thin platform of Flox so it sits nice and flat. Curious how others have done this step!
Eric Rushing
VS, Rudder, HS, Elevator, Tailcone - Complete
QB Wings - Complete.
QB Fuse - In Process. Tail & Fuse are one.
Molalla, OR
Old 03-24-2017, 04:11 PM
Since mine are already mounted, I have to trim the visible end. So it's gotta be pretty... And (at least in my hands) the results from a belt sander are not pretty. ;-)
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 03-25-2017, 08:37 AM
Carlos Trigo Carlos Trigo is offline
Kyle
I am a bit puzzled with your request.
Can't you just move out the cam those 1/32"?
I know that it is a bit difficult to move the cam if you already have the pin drilled and fit, but if not, it's easier.
Carlos
Old 03-25-2017, 08:45 AM
Originally Posted by Carlos Trigo View Post
Kyle
Carlos
It isn't a cam issue.
The issue is the pin guide blocks on the doors hit the pin receiver blocks which are mounted to the cabin. This prevents the doors from closing. There is 1/16" or thereabouts of interference.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 03-25-2017, 08:57 AM
snowbear26 snowbear26 is offline
For such a small amount you could try a sharp file (new would be best). It would provide a better finish than a sander and you might be able to leave the blocks installed.
Mike Z.
RV-10 - Emp. Kit
Old 03-25-2017, 02:31 PM
leok leok is offline
I was just working on the blocks today. My 12" disk sander from HF did a nice job of removing extra material from the blocks.
Building my RV-10 since Oct 5th 2014
Flying .. once I figure out how to pay for everything
http://www.mykitlog.com/leok
RV Hotel
Dues paid 2018
Old 03-25-2017, 06:59 PM
Strasnuts Strasnuts is offline
Default Sanding the blocks
Delrin should be easy to sand and you want to sand the bottom surface that is against the cabin top. On my RV10 I sanded a spot for them on the cabin top then sanded the bottom of the guide a little. Like you said you want to "capture" the door in place so it doesn't shift fore or aft.
A&P RV-10 Flying 850 hours
SuperSTOL Flying 100 hours
Old 03-25-2017, 08:53 PM
Post-script:
Do not try and use a jointer on Delrin. It chips out rather badly.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 03-26-2017, 02:03 PM
BigD BigD is offline
I used the sticky backed sandpaper that comes in rolls, which is handy for long board sanders and block sanding. Stick it down to a flat surface (workbench) and rub the block into shape. You can progress through finer grits to get a nicer finish.
N102FM
