Old 03-23-2017, 05:07 PM
DonFromTX's Avatar
Default Side Brace
I had been "about to" do this for years, and finally got around to it today. Especially during build, this piece gets pressure on it and bends down, then you bend it back up - over and over again! Easy, cheap fix, I would recommend everyone do it![IMG][/IMG]
Retired US Army Officer
Old 03-23-2017, 05:29 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
I do not get why it is needed?
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2018 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 03-23-2017, 05:38 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
For those of us who crawl into our planes😎
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 03-23-2017, 05:58 PM
DonFromTX's Avatar
Especially for us that are so old we are not graceful getting in or out!
Old 03-23-2017, 09:17 PM
Jim T Jim T is offline
I like that Don! Thanks for posting.
Jim
RV-12 kit no.: 120647
Working on finish kit
http://www.mykitlog.com/JimT
2006 Rans S-6S Coyote (flying)
Old 03-23-2017, 10:02 PM
BOORSMA BOORSMA is offline
I did exactly the same thing and it is much stronger and no more bending. Vans should evaluate making this change.
D. Boorsma
RV-12, Bakersfield, CA
Old 03-24-2017, 11:29 AM
One time I was off balance while standing on the passenger step. I grabbed hold of F-1254-R and bent it. To prevent that from happening again, I riveted a 7" long channel to the underside of F-1254-R. The channel is not visible unless you put your head on the seat and look up. All that is visible are 6 rivets on the top surface of F-1254-R. The advantages of my fix are no compound curves, no exposed sheet metal edges, and no worry about minimum distance between rivet holes and edge of F-1254-R.
Joe Gores
RV-12 Flying
Old 03-25-2017, 01:52 AM
bobnoffs bobnoffs is offline
my reinforcement pieces were cut and drilled 6 months ago. haven't been put in yet.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying
RV-12 kit as of 9/13
Old 03-25-2017, 08:42 AM
DHeal DHeal is offline
I agree that this brace is a very useful addition to the RV-12 cockpit structure -- I installed it immediately following my A/W cert inspection. Simple to make and install. The only down-side is future access regarding the canopy's plastic guides on the rail should the guides become worn or loose (unlikely IMHO).
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 635+ hours (as of May 2018)!
VAF donation through June 2018.
Old 03-25-2017, 09:21 AM
rgmwa rgmwa is offline
I installed one a long time ago. Mine's about half as long as Don's but works very well. This is something that Vans should incorporate in the kit.
rgmwa
120346
