Old 03-22-2017, 06:50 PM
Ralph Inkster Ralph Inkster is offline
Yep, guess it's up to who you get on the tech line.
I like the idea of Tinnerman washers too.
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
Old 03-22-2017, 06:53 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Originally Posted by sbalmos View Post
Well Gus /is/ with Vans. And he didn't seem concerned (used the classic "none have fallen out of the sky" line on the phone).
I hope that's not his only justification!
Carl N.
Arlington, WA (KAWO)
RV-8, 280 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
Old 03-23-2017, 04:34 AM
Mark Dickens's Avatar
Perhaps the way to look at it is that those fairings are certainly aerodynamic if not truly structural. I've heard a story from a reliable source that flying the plane without them installed makes the plane almost uncontrollable. Don't ask me why this happened...wasn't me. My aft-most hole on the bottom didn't match well and I had to elongate the hole in the fairing and use stainless tinnerman washers to finish the job. Stainless and aluminum will corrode, so prime the inner surface of the washers.
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight November 20, 2016 - Phase One Complete June 1, 2017
Old 03-23-2017, 05:44 AM
bret's Avatar
bret bret is offline
Not an engineer nor did I stay at a Holiday Inn Express last night.....but, I can see this adding to + G strength with the bottom skin all connected in tension
2018 gladly supported
Old 03-23-2017, 06:10 AM
6 Gun 6 Gun is offline
Exclamation screws
Yep I went to search and found lots of info on this subject as I had a ? a few years ago on this same subject.The RV3,4,6 were load tested with out screws in place and 7,8,9 with screws in place so yes they are part of the wing!
Bob
Old 03-23-2017, 07:53 AM
BillL BillL is offline
Bob
Odd that Gus would say not structural. Vans will compromise on cosmetics, but not safety. Maybe he assumed that they would still share the loads even if elongated, at least in this direction. He has a lot of experience and surely this discussion has been thrashed with engineering.
Anyway - although they carry some load, the pitch/spacing is not adequate for full skin load transfer, so Scott could just add screws between existing ones and move on. This addresses the strength and offset issue. OTOH - this shifts loads to the skin, and changes the load balance of the structure. Jon Jay said his screws loosened periodically for a while then stopped. So, clearly they do carry see some load, but how much they carry is open for analysis. Back to Vans.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 03-23-2017, 09:40 AM
JonJay's Avatar
JonJay JonJay is offline
Another CI or two since that report and they are still tight. There could have been other factors at play. However, the rear spar bolt discussions and confirmation from Scott McD, that joint can move. If it can move, that belly skin must be taking some load at some point. I would suspect it isn't going to be cause or a factor in a wing failure. As you point out, there are too few screws to put that sheet to much work.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-23-2017, 10:03 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Or simply take those screws and washers out when the plane is painted.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-23-2017, 10:40 AM
Janekom's Avatar
Janekom Janekom is offline
Default I thought they are strutural
A couple of years back I also had an RV7 in my shop without those screws. Asked Vans and the reply was: Do not attempt to fly that aeroplane as it is structural. Cannot remember who it was but I find it interesting how opinions differ
Jan Hanekom
South Africa
AP 325, AMO 1256
http://www.rvbits.com
RV10 - ZU-XOX - (Fuselage)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Sold Flying)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2018
Old 04-02-2017, 01:21 PM
rv8builder2014 rv8builder2014 is offline
Default Screw alignment issue
Did you go back and check the angle of incidence on the wing as well as check the wing for forward and aft sweep after you ran into this problem? That is where I would start. Wing twist shouldn't be an issue with this particular problem.
