Old 04-08-2017, 09:42 PM
AirHound AirHound is offline
Originally Posted by MMiller View Post
4/8/2017 update
This improvement may cause other issues...see post 78 below
Dave,
Iíve been giving a lot of thought to your question about improving the regulator while itís opened up. We know these regulators fail from stresses in the power component leads. I always assumed these were operationally induced stresses. Iím beginning to rethink this theory. Yesterday I took apart a regulator (from the Sport Cruiser community) that was sent to me last week. This was a real eyeopener into the poor build quality by Ducati. Iím now wondering if these stresses were loaded on the components during manufacturing. With the new pliable gel potting compound the Operational vibrations induced on these pre-stressed leads may be enough to fracture the solder joints. This could explain why some last 10 hours and some hundreds of hours. Anyway, back to your question. There is a screw that holds down the bridge rectifier. My thought is to remove the screw, add an insulator and a washer to the screw and clamp both the PCB and the bridge. Then resolder the bridge and SCR leads to relieve any stresses. This will prevent any relative movement between these two parts.
As for that Sport Cruiser regulator
Thinking hi-adventure for those mounted in the cockpit which smoke and sputter to a short...
Doug
Old 04-21-2017, 02:39 AM
omerward omerward is offline
Default VR repair
Mike, I can't thank you enough for your thorough analysis of the VR failures. Mine had a burned G pin just like your photo. I opened it up and the solder connection from the pin to the PCB was cracked. I made a good solder connection on both G pins and it is working fine so far. Thanks again for your analysis.
Sam Ward/Conroe, TX KCXO/RV-12 Flying
Old 04-21-2017, 08:00 PM
MMiller MMiller is offline
Great job Sam, You're welcome and thanks for the feedback.
One suggestion, to increase the current carrying capacity of the G pins, donít use the black Rotax plug. Connect the fastons directly to the regulator. This will give you 100% mating contact.
Vanís, Rotax, Ducati, if you are listening...The Rotax 965-349 Ducati 362001 rectifier regulator is not a lost cause, but you need to deal with the design and manufacturing deficiencies if you want to put this behind you;
1) Eliminate the manufacturing induced lead stress on the power components.
2) The potting compound is too soft, and it's unstable over the rated operating temperature of the regulator. (95 Shore A to 30 Shore A)
3) Operating stresses (vibration) acting on the pre-stressed leads (item 1), in a potting compound that softens with temperature (item 2), over time results in PCB solder joint separation failures.
4) PCB connections that were never soldered indicate a poor (or nonexistent) inspection/QC process.
5) Insufficient clearance between an un-fused, high current carrying PCB trace and the rectifierís grounded metal case. The design relies on the insulating value of the PCB's solder mask layer.
6) Poor connector/plug/tab length design. The design of this 22 amp connection only allows about 80% of mating capacity between the connectorís male tab and female AMP fast-on.
7) The material for the male tab is 7.5mm thick, this equals .0295", the AMP faston is designed for an .032" tab thickness. The design falls 8% below optimum thickness.
Mike
Old 05-15-2017, 03:32 PM
Slane Slane is offline
Default VR Meltdown
During a flight last week, I had a faint smell of something burning. Upon landing I examined the voltage regulator, which is located under the instrument panel. The following images display what it is I saw.
https://srlane9.tumblr.com/post/160707507168/vrmeltdown
This is the second VR I've installed. The first was installed on the shelf forward of the firewall. The first VR lasted approximately 75 hours while the 2nd one lasted 200 hours.
There didn't appear to be an indication of a pending VR failure with no irratic fluctuations in either voltage or amps.
Next step for me will be to download data from skyview to see what it is that I missed.
Looks like some wiring repair and another VR installation.
Scott
Scott Lane
Hillsboro, OR
RV12 Completed & Flying 2013
#120043 N728SL
VAF paid 2018
Old 05-15-2017, 03:40 PM
DaleB's Avatar
DaleB DaleB is offline
That looks like it could be just a connection failure. The regulator may be OK. I'd suggest taking the wires out of the connector and seeing what damage there is to them.
It's been observed before that the standard connector doesn't fully mate the spade connectors, even when fully engaged. If you had a wire not quite completely seated it could have caused a flaky connection, heating, arcing and the results you see.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 05-15-2017, 09:14 PM
Default VR Meltdown
Thanks for the replies. I removed the VR and upon closer inspection, the "R" connection may not have had an adequate connection. I like the idea of skipping the black connector but want to be sure the VR is still viable. Is there a way to test the VR?
Scott Lane
Hillsboro, OR
#120043 N728SL
VAF paid 2018
Old 05-16-2017, 12:18 AM
Yes, place it in the round can in your garage that you haul out to the curb once a week...
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 318
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 05-16-2017, 04:30 AM
If you're doing the mod anyway, do it now & plug the individual fastons onto the current regulator, & try it.
