Old 02-16-2017, 09:42 PM
Mark C. Mark C. is offline
Default mounting LED Bulb
Steve, even if you modify the mount. Like only use a section of it, not a 360deg. hold of the bulb. I love the idea because of setting the angle for the light beam to come out straight. Mark C. RV9A
Old 02-17-2017, 09:36 AM
Av8torTom's Avatar
Default Great find
Hopefully they will be available again soon or from another source.
Do you have any pics at night? Have you used them landing yet? How was it?
Tom
RV-9A (empennage completed, both wings completed, ready to hang engine)
N677AT reserved
Superior XP O-320, 160HP
Old 02-18-2017, 08:47 PM
Default PAR36 design
has promise but will not fit RV-9 wing tips. maybe someone else can use it. still some dimensional tweaking to do. weight without fasteners = .39 lb. rotate base and wedge to achieve beam angle. I need to add some cooling vent holes in the base. you know, a couple hours Thursday and three hours today, hit the print button and go to the airport and go flying. when you get home the parts are ready.... it's a new age folks. and many thanks to EAA and Solidworks for the free software.
comes with drill template
maximum angle, clock base and wedge to angle desired
zero angle
Old 02-28-2017, 07:30 PM
Default not sure what it's good for
more of an exercise than anything. +/- 10 degree option at install. this light is rated at 18W and the max operating temp ~120F. I suppose I could chop off the base at the bottom of the lower wedge and eliminate an inch but that would eliminate those cool hex nut features.
Old 03-16-2017, 08:52 AM
ecurington ecurington is offline
Default Back on Amazon
I see these are back available on Amazon. A ordered a pair to play with. Planning on mounting them in the leading edge Duckworks hardware.
Eulice Curington
RV-10 N104EW
Painting
Old 03-18-2017, 12:27 PM
krw5927 krw5927 is offline
Just mounted a pair of these in my leading edge Duckworks mounts. I previously had Duckworks PAR36 reflectors with 35W HID lamps, and these are noticeably brighter.
The only modification that was required was a washer between the rear mount plate and retaining cup because this LED lamp is a bit thicker on the front side of the mount. I removed the HID driver circuitry and wired these up instead, and the weight difference was a wash (actually saved a few tenths of an ounce per side).
Went flying for the first time with them today, and they were completely silent electrically and didn't affect radio transmission or reception one bit. I just ordered more for replacements if these ever quit, because I'm sure once everyone gets word about these they're going to disappear FAST!
Kurt W.
RV9A
FLYING!!!
Old 03-19-2017, 07:02 AM
Tbone's Avatar
Tbone Tbone is offline
Default Question
Do these lights have capability to wig-wag effectively?
___________
Terry
RV7
XP IO360
Old 03-19-2017, 10:19 AM
Yes, but much depends on your wig wag controller. If you use the B&C controller, there will be an extra couple of resistors needed. I think the setup is in their wiring instructions.
I built my own controller with no moving parts, which does not depend on a resistive element being connected for switching. Works a treat!
Kurt W.
RV9A
FLYING!!!
Old 03-25-2017, 08:11 PM
RV6grin RV6grin is offline
I was glad to see these become available again to give them a try...Wow! They throw quite a bit of light for low power. The Duckworks leading edge kits are on order and can't wait to get two of them installed. This pic is just one of the lamps positioned at the left wing outer bay with a 12v battery attached. The dimly lit fence across the field is about 400 ft.
______________
David N.
RV-6, N164SP
Got one that was built with care & lovin' it!
Old 04-15-2017, 07:51 AM
exercise exercise is offline
Where would one go to purchase the RV4 wing tip assembly that Xkizme1 has? I'm ready to to the full LED swap and all his lights within one lens seems like a good way to go.
THX, John in MN
RV4 salvage project
IO-320 C/S
hope to fly it in spring 2018
0601054 att gmaill dot comm
