Old 04-10-2017, 11:01 AM
Raymo's Avatar
Raymo Raymo is offline
Take a close look at the new Dynon ADS-B in box they just announced and you'll see the uAvionix logo. Wondering now if I can just install the uAvionix IN device and not have to deal with the trade-in option and cost.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 04-14-2017, 08:29 PM
dwschaefer's Avatar
dwschaefer dwschaefer is offline
Default ASDB / Mode S
I talked with these guys at Sun 'n Fun ... very interesting engineers. GRT is going to route out the top of their GPS to mount this box to make one very small package. Interestingly, they will have a ADSB/Mode S unit available if I remember correctly in the 1200-1600 range. The GRT or most GLASS will be able to set the code, like with any remote mounted transponder. Oh ... it will also have WiFi out for tablets.
A company to watch.
DWS
N142DS RV6-A
"Nerdgasm"
Old 04-21-2017, 01:28 AM
Has anyone installed UAVIONIX ECHO-ATU-20 yet?
Hinckley, Ohio
P/ASEL 1970 Sport Pilot since '04
RV-12 E-LSA #120058 AWC 7/12 Bought Flying 10/15 with 48TT - Hobbs now 317
LSRM-A Certificate 2016
Old 04-24-2017, 11:44 AM
n468ac's Avatar
n468ac n468ac is offline
I'm in the process of installing ... hoping to have a test flight next weekend.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 04-25-2017, 02:48 PM
Dan92 Dan92 is offline
Default Echo Installed
I finished the install of the Echo today and the setup app says that it's working although I haven't test flown it yet. I'm getting the 2020 compliant GPS from the GNS430W and the install was pretty easy. I had to make a couple of calls to Uavionix support and they (Ryan) were very helpful.
Dan
RV-7A
Old 04-25-2017, 03:40 PM
Rupester Rupester is offline
Default Another Volunteer testbed ...
Dual GRT Sport SX with Garmin 327. Will purchase the GRT SafeFly GPS upgrade.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 04-26-2017, 11:30 AM
TomVal TomVal is offline
How many of you above in the process of the install are considering the wireless transponder interface?
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 04-30-2017, 07:11 PM
Just to add a positive note dealing with the uAvioni support staff...they responded to my written questions the following morning. The pilot/installation manual did not specify what size CB was required, nor stated the minimum separation distance required between the transponder and ADS-B antennas.
Support replied that a 1 amp CB is sufficient and the ADS-B antenna should be mounted a minimum of one meter from the transponder antenna. The reference to the CB is now on page 14 of the online manual. The antenna info has not been updated.
I installed the antenna today and ran the RG-400 through the center tunnel. Haven't decided where I am going to locate the transceiver yet. The limiting factor is the maximum length of coax. It cannot exceed 2.59 meters to limit db loss. My current thinking is to mount the unit under the instrument panel near the tunnel.
I opted for the GRT Sky-Safe 2020 GPS. It is on backorder so I am taking a time-out from the project.
Tom Valenzia
RV8 (Sold)
Old 05-02-2017, 06:21 AM
I have an old Garmin 327 so this could work for me. The options keep coming if I keep waiting.
Old 05-02-2017, 09:20 AM
RVbySDI's Avatar
RVbySDI RVbySDI is online now
Same here. I am in the civilian version of the military's "Hurry Up and Wait" mode.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
