Old 01-05-2017, 05:19 PM
olderthandirt olderthandirt is offline
Default fuel Pressure
so today coming back from flight the fuel pressure went to 5.7 PSI and started blinking yellow, I pulled electric fuse and it settled to 5.6 and no yellow blinking light..anything to worry about?? Also climbing out today at 75 MPH I was getting 5140 RPM not 5200 again anything to worry about???l Thanks
Retired Firefighter/Para-Medic
Sold 182 Skyelane
sold Super Cub
Building RV 12 E-LSA
Paid thru 2016, even though exempt
RV 12 completed, waiting DAR
Old 01-05-2017, 06:40 PM
Better high than low!
Old 01-05-2017, 06:56 PM
Seems to be all over the place---up and down. Early December it was low----hum
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 03-24-2017, 05:31 AM
D&M Dan D&M Dan is offline
Default Low Fuel Pressure Warning
Finally got some good flying weather in Upstate NY yesterday and was able to do the first flight. What a blast and what a great handling airplane.
I have a couple small issues, mainly with the Dynon, but the one that concerns most is with a fuel pressure warning on climb out. Pressure drops to 2.2psi and the "fuel pressure" starts chiming in the headset.
I have 18 gal. fuel onboard and engine is smooth as can be. Strainer was cleaned before flying. Fuel pressure in straight and level flight is 2.9psi and flow is 5.2gph.
Any ideas where to look?
Dan
N930DD (Registered)
Home Field KSDC
Paid 2017
Old 03-24-2017, 06:46 AM
You should see ~ 2psi from the electric pump when master is switched on. When engine starts the mechanical pump adds ~ 3psi. So, with engine running and both pumps operating ~ 5 psi is what you should be seeing as normal operating fuel pressure.
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 333
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 03-24-2017, 07:14 AM
BigJohn BigJohn is offline
Dan
Dan, first of all you would probably get a better response on the forum if you had started a new thread with a more descriptive title. You have hooked on to an old thread that sounds like a different problem. Be that as it may, in order to make any kind of helpful suggestion more information is needed.
Fuel pressure with engine off and electric fuel pump on.
Ground run pressures at several RPM points ranging from idle to WOT. Do this twice, once with electric pump on, and agin with electric pump off.
Let us know results and we can go from there.
VAF paid through 10/2018. Best bargain in town.
Old 03-24-2017, 07:18 AM
Dont know about alot of the 12 guys, but 2.2 seems to be the magic number on the fuel pressure.
Tom
Ridgeland, SC
Old 03-24-2017, 08:45 AM
Will do as you suggested John next time I am able to get to the airport. What are most seeing for fuel pressure? Should I be in the 5psi range at all phases of engine run and flying?
N930DD (Registered)
Home Field KSDC
Paid 2017
Old 03-24-2017, 10:01 AM
tomkk's Avatar
tomkk tomkk is offline
I just checked mine recently. 2.8 psi on electric pump only, 5.1 w/ electric & engine pumps. I run both pumps in the air but did check the engine pump only in cruise and saw 3.5 - 4.2 on engine pump only. I tried that on another flight and saw as low as 2.? - don't remember the precise pressure but it was just at the bottom of the green on the engine pump only.
This is all with 93 octane auto fuel with 10% ethanol.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845
First flight 06/10/2015
Old 03-24-2017, 10:49 AM
With a brand new airplane the first thing to check should be the screen in the gascolator.
Once you start taxiing around and sloshing fuel in the tank it is not uncommon for some debris to get flushed out of the tank and hoses, and plug a portion of the gascolator screen.
Scott McDaniels
Hubbard, Oregon
