Go Back   VAF Forums > Model Specific > RV-4
Old 04-14-2017, 07:03 PM
xti xti is offline
The boat is done and shipped to Alaska. But sold another for a June delivery and hopefully my crew will allow time for me to dig into this rv4.
Does anyone have rv4 parts laying around?
Not sure what all I need yet, but..
2ea A-403PP-L (Spar)
16ea A-710 skin stiffeners
basically all the aileron pieces, except the skins, I have those.
If not, is the best way to buy individual part #'rs from Vans?
Travis
rv4 '93 build in progress
Old 04-14-2017, 07:37 PM
Sam Buchanan's Avatar
hall monitor
A little poking around produced the following link for Travis's company:
https://www.xtaeroboats.com/home.html
I suspect he is going to build one fine RV-4!
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 04-15-2017, 04:37 PM
xti xti is offline
Originally Posted by Michael Henning View Post
Hi Travis,
I built my -4, and if I had to do it over again, I would use RV-6 fuel tanks. The cg, and extra weight won't be an issue, as you can adjust your fuel load based on your mission requirements. Get to building, it is an incredible machine.
My mods are-
Moved roll bar back two inches (6'2", 245 pounds, and I fit perfectly)
Removed an inch from bottom of instrument panel
Two RV-10 vents installed
Todds canopy
Wing tip lockers as shown in RVator
Thanks for the info Micheal, this is probably the scenario I'll try to do... is there a way to convert my -4 tanks to the -6 tanks? what is the difference between? Since my -4 kit is the slow build kind I have loose skins and haven't installed the caps or fastened anything permanently yet it seems like the only option of extra gallons is to extend the tank outboard? is this correct?
Travis
Old 04-15-2017, 07:44 PM
Billvt's Avatar
Billvt Billvt is offline
Default What's This Hole in My Firewall
I purchased my RV-4 project from an estate sale.
Builder deceased so can't ask questions.
What might the 2" hole in the firewall pictures below be used for???
http://i.imgur.com/wkPEwWi.jpg?1
http://i.imgur.com/4lmE8Nl.jpg?2
Bill Morelli - A&P I/A - EAA Tech Counselor
Up North Aviation
CNC Instrument Panel Fabrication
Web www.upnorthaviation.com
E-Mail upnorthaviation@gmail.com
VAF advertiser
- RV-4 build in progress !!!
Old 04-16-2017, 01:38 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Only firewall item that really makes sense would be a heater selector/bypass box -
http://www.vansaircraft.com/cgi-bin/...t-selector-box
But would it be that low on a RV-4 firewall?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-16-2017, 06:21 AM
Michael Henning Michael Henning is offline
Hi Travis,
Steve Arnold mentioned that with the Phlogiston Spar(which is what I have), you can't modify to the -6 tanks because of the mounting flange. Wouldn't worry about the extra gas. I make it from NH to NC on a tank of fuel, and am ready to stretch by then anyways.
I believe skin stiffeners for the ailerons are fabricated from 3/4"x3/4" x .032 aluminum strips. That's just going from memory, so I could be wrong. I wish I lived close by, I miss building (except for fiberglass).
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 04-16-2017, 09:39 AM
SJordan SJordan is offline
I'm just working Firewall forward on my -4 and all I can think is the heater door like Gil said. Though yours appears to be to low to use as the lower engine mount tube is in the way. Maybe you can build a stainless patch and run your fuel line there.
Old 04-16-2017, 10:48 AM
az_gila's Avatar
Smile
Hi Travis,
Yes, but not quite as hefty.
They are 5/8 x 5/8 x 0.025 angles simply bent from flat sheet.
Apparently changed (at least for the -6 models) in 1994 from 0.016 thickness
Gil Alexander
Old 04-16-2017, 01:18 PM
Steve Barnes Steve Barnes is offline
Default Larger tanks can be done. Done over 15 years ago
I forget exactly how I did it. I remember partially deconstructing the Phlogiston spar (drilling out the big rivets adding an additional flange and reriveting) Also added some little square blocks between upper and lower spar laminations. Got the info from John Harmon.
Steve
