Old 04-07-2017, 05:21 PM
Carl Froehlich's Avatar
Originally Posted by snopercod View Post
I ran mine up front to the starter pad. That's where the heavy load is.
+1
Use the nice ground lug on the starter motor - that is what it is there for. Wire size to the starter ground lug the same as you have providing power to the starter. Ground wire from the starter then runs to the common ground lug on the firewall (I use the one with the "forest of tabs" on the cabin side").
Old 04-07-2017, 06:42 PM
BillL BillL is offline
I am the odd man out.
I used the case as noted with a braided strap from B&C. Thanks for the pict, Andy.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 04-07-2017, 07:35 PM
Bavafa Bavafa is offline
Originally Posted by bruceh View Post
I got my engine (IO-320) grounded to the firewall (one of the lugs on the forest of tabs ground block on the interior side). The other lug on the firewall will connect to the negative side of the battery. I used 2AWG welding cable and connected it to the vacuum pump accessory location.
This is where my ground strap is bolted on to the engine and then from the same bolt on the FW goes to the battery so in essence a direct [copper] path from the battery to the engine, intercepted by the airframe.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 04-09-2017, 08:16 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Originally Posted by Carl Froehlich View Post
+1
Unless it doesn't have one, like the SkyTec...
Old 04-10-2017, 01:28 AM
rv8ch rv8ch is offline
Default ground straps
Here's what I ended up doing. Click on image for more pictures.
Mickey Coggins
http://rv8.ch
Old 04-10-2017, 06:32 AM
Scott Hersha Scott Hersha is offline
I used that hole on the case flange just above the lower right engine mount - the one with the red arrow in the picture above. I just tapped this hole for the appropriately sized bolt and used a toothed lock washer to secure it. It's easily accessible with the engine mounted, and not in the way of anything else on my engine.
Scott Hersha
2001 RV-6 - sold 2005
2008 RV-8 Fastback - Sold 2016
RV-14 Wings - sold 2014
RV4 - Sold
Cessna 182RG - flying
New RV8 - Finished and flying 4/26/18
Cincinnati, OH/KHAO
Old 04-10-2017, 08:49 AM
Larco Larco is offline
Have seen many connected here as well
Old 04-10-2017, 09:11 AM
RViter RViter is offline
Default Could be worse ...
Originally Posted by VETE76 View Post
my friends rv7 w/lyc io360was very hard starting. we had a tech counsler come over and he asked to see the engine ground strap. so we took the cowl off and showed him. he asked us to unbolt it, we did, he looked at he place we bolted the wire to, he asked whats all this engine paint doing here? remove it. we did. engine spun over much much faster and started right away. never a problem again! food for thought.
This could have been worse, and I had it happen, on the first few attempts to start my O-360. Actually fried a wire to the ignition switch. The engine barely turned over with the plugs installed, but had turned easily on the test with plugs out of the top. After a 2nd or 3rd attempt I smelled a hot wire, saw the Tefzel deformed, and felt the heat to be sure my eyes were seeing the problem.
Due to a distraction, I'd laid the ground strap on the bench one day and never connected it to the engine or the firewall. An ignition switch lead had become the only "ground wire" because it was the only path. Replaced the lead, installed a ground strap, and cautiously tried the starter ... ZING, sounded good.
It has given me cautionary approach to starting the engine. If ever it fails to turn over well, I will check the battery voltage 1st and the ground strap continuity 2nd, before cranking away at a crawl.
gary
RV-6A QB Tip-Up, 1st Flight 3/18/17
O-360-J2A (modified & F/I), Sensenich FP (cruise)
VP-X Sport, Dynon SkyView, VFR day
(FFZ) Mesa, AZ - N234GB -
www.mykitlog.com/garyc
