Old 08-25-2013, 12:11 AM
ao.frog ao.frog is offline
Default Where to install the engine ground connection on a IO-360 Lyc?
Hi gang.
I'm wondering where you all have installed the ground connection on the engine?
One end of the ground cable goes to the battery, so that's easy, but where on the engine do I connect the other end?
On my first 7, the engine manual (Extreem IO-360) showed where to install the ground connection, but on my new -7, the Lycoming manual doesn't show any main ground at all, as far as I can see.
So, instead of guessing any further, I ofcourse put up a post on this great forum.
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 100 hrs pr Jan 2016. Life is good!
Old 08-25-2013, 04:49 AM
dav1111 dav1111 is offline
Super Moderator
Instead of grounding to the battary you might just consider grounding directly to the firwall as I assume you have or will install a ground bus on the firewall to run most of your grounds. I installed a back to back ground bus inside and outside of my firewall and ran the engine ground to the post holding the ground bus in place on one side and ran the battary ground to the post on the other side of the ground block.
The engine side of the ground bus can be installed on almost any nut on the back side of the engine that is handy. Just make sure the the ground strap has a little play for vibration purposes.
Russ Daves
Lubbock, TX
Proud to be a Veteran
N710RV - RV-10 Flying
N65RV - RV-6A Sold
N686RV - RV-6A Re-Built, Sold
N742PZ - RV-8 Co-Builder Sold
N-867RV -RV-7 Finish Kit
VAFWWW Dues Paying Member
Old 08-25-2013, 07:03 AM
crabandy crabandy is offline
Found a pic on google, there is a lug just above the lower engine mount on both sides. I bolted my ground strap to the lug on the right side just above the lower mount slightly rearward of the oil dipstick. It's my understanding that any bolt on the back of the engine can work, but its best to use the lug on the case
Old 08-26-2013, 08:43 PM
OLDSAM OLDSAM is offline
Default Be sure it is big enough
If you do install a ground conductor from the engine to the airframe, remember that it has to be large enough to carry the current required by the starter motor, as do the terminals at each end where it connects to the engine crankcase and to the firewall
OldSam
RV7A, Empennage, Wings & Tanks complete
Fuse under way
Old 08-28-2013, 12:21 PM
VETE76 VETE76 is offline
my friends rv7 w/lyc io360was very hard starting. we had a tech counsler come over and he asked to see the engine ground strap. so we took the cowl off and showed him. he asked us to unbolt it, we did, he looked at he place we bolted the wire to, he asked whats all this engine paint doing here? remove it. we did. engine spun over much much faster and started right away. never a problem again! food for thought.
Old 08-28-2013, 03:09 PM
bruceh's Avatar
bruceh bruceh is offline
I got my engine (IO-320) grounded to the firewall (one of the lugs on the forest of tabs ground block on the interior side). The other lug on the firewall will connect to the negative side of the battery. I used 2AWG welding cable and connected it to the vacuum pump accessory location.
Bruce Hill
RV-9A N5771H flown over 500 hours!
2017 VAF donator
EAA Tech Counselor
Old 04-07-2017, 11:41 AM
rv8ch rv8ch is online now
Default ground strap
Hi Bruce, did you end up staying with this location? Looks pretty clean to me.
Mickey Coggins
http://rv8.ch
Old 04-07-2017, 12:55 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Pretty much exact same setup, but used braided grounding strap (forget which vendor I got it from)...works great, easy to inspect pre-flight.
Old 04-07-2017, 12:59 PM
snopercod's Avatar
Default starter pad
I ran mine up front to the starter pad. That's where the heavy load is.
(2018 dues paid)
Old 04-07-2017, 01:32 PM
gyoung's Avatar
gyoung gyoung is offline
Same here. Got the strap & terminals from Stein. Easy to crimp on #2 terminals.
Greg
1950 Navion - flying
RV-6 - 15 yrs and 96.3% done
3.5 L-2 projects on deck
