Old 03-29-2017, 10:50 AM
jmjula's Avatar
jmjula jmjula is offline
I had asked Van's what to do and was told it doesn't hurt anything to leave them full weight until painted, then drill holes to balance, if you want to. Extra weight doesn't hurt, too little weight very well could. I just finished the painting and can trim a little from the right side when I feel like doing so and touching up the paint to cover the removal hole(s).
James Jula - CFI/II/MEI - N713JL RV-7A First Flight 10/12/15 - "What is chiefly needed is skill rather than machinery." Wilbur Wright, 1902
Old 03-29-2017, 10:55 AM
Reformed SeaSnake Reformed SeaSnake is offline
Default Wait
Originally Posted by RV7ForMe View Post
hey Larry I know this thread is a few years old. but i am asking the same thing now. how did it turn out? was leaving it as is the right move?
I can't speak for Larry, but I went through the same decision finishing my 8A empennage a couple years ago. I elected to wait until final paint. It's easier to trim/drill out than add back and paint can add quite a bit of weight to those elevators.
Also, if you are planning (like me) to fly the plane for awhile before painting it, there is no harm in having control surfaces that are a bit over-balanced.
Jason Rood
Beaverton Oregon | RV-8A, Very slow QB
No Pithy quote here; just the sincere hope that your day ends better then it began
Old 03-29-2017, 04:05 PM
wirejock's Avatar
wirejock wirejock is offline
Default Weight
I'm not flying yet but have had the tail together and right was just about balanced. Left will need a tad due to the trim but she's not finished yet. I plan vinyl wrap. I will add nut plates to the tooling holes for weight adjustment later.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 03-29-2017, 09:31 PM
Chattin35 Chattin35 is offline
Default Elevator balancing
I also called Van's about this (twice actually, haha). I was paranoid because the RV-4 manual dedicates quite a bit of info to balancing the elevator. They said it wasn't that big of a deal on the -7/8. Balancing the elevator is pretty much optional, but be sure wait until everything is installed and painted if you are going to do it.
I'm still a little wary about this as flutter is one of those things you don't want to mess with. It can kill you very quickly. But, I'm taking Van's word for it right now (might call again before I fly it just for good measure).
Old 03-30-2017, 04:17 PM
RV7ForMe RV7ForMe is offline
alright thanks guys. So I will leave it uncut for now...
VAF dues paid until 05/2018
RV7 - Empennage 95% done
RV7 - Wings Started...
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 03-30-2017, 08:54 PM
efitzgerald efitzgerald is offline
Default Getting ahead of the plans
Its a good thing I took a look at this thread. I was not reading ahead and cut both weights the same as shown in the picture of the right elevator. I ended up milling them and it was easier to do them at once.
I have not finished the left elevator yet but the weight has already been match drilled. What is my best course of action at this point? Drilling another weight and getting the holes to match up will be pretty hard (lead is not fun to drill).
Eric
Old 04-05-2017, 06:37 AM
This is my weight for the left elevator. As you can see I cut it the same way the right side is. I have already match drilled it to the elevator, what would be the best way of fixing the mistake. I am assuming that it is going to be difficult to drill a new one and gets the holes to line up perfectly with the rib on the inside.
I was considering using some aluminum sheet metal to create a "mold" so I can heat that end up enough to melt it and add more lead to bring it back to its original shape.
Thanks for the suggestions in advance.
[/url]
