Old 06-10-2013, 03:25 PM
wirejock's Avatar
wirejock wirejock is offline
Default Elevator counterweight
I have another elevator question.
E-714 Elevator Counterweight
The right side plans show an area to cut away. The isometric view shows it removed.
The left isometric view show it uncut.
The book does not mention it till it talks about balancing and drilling small holes.
I've learned the plans are almost always right but in this case the two plans do not agree.
So should I cut or leave it and cut it later when balancing?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 06-10-2013, 03:54 PM
larrynew's Avatar
larrynew larrynew is offline
Only the right gets trimmed. DWG 5, E-714 Trim Detail says, "...Right Elevator Only!"
Larry New
RV-7A - Flying 500+ hrs
VAF Paid - Annual Autodraft
Old 06-10-2013, 05:13 PM
bret's Avatar
bret bret is offline
on mine I did not remove any, with paint and electric trim, I only had to drill a few holes in each one to balance it, with them tied together.
2018 gladly supported
Old 06-10-2013, 06:13 PM
wirejock's Avatar
Default DOH!
I must have read that 50 times and still missed the note. That makes sense. I was wondering if balance would be different between the two sides due to trim hardware.
Thanks Larry.
I think I will cut away the area shown.
I wonder what else I missed.
Larry Larson
Estes Park, CO
Disclaimer
Old 06-10-2013, 06:17 PM
wirejock's Avatar
Default Electric trim
I'm using electric trim also. Hmmmm. Oh bother!
Maybe I should leave it as is. It can be cut away anytime.
Thanks Bret.
Larry Larson
Estes Park, CO
Disclaimer
Old 06-10-2013, 06:21 PM
wirejock's Avatar
Default Familiar
Larry, do we now each other?
I am from Austin.
Your last name seems familiar.
I worked 30 years for AISD.
Larry Larson
Estes Park, CO
Disclaimer
Old 06-11-2013, 09:02 AM
cjhammes's Avatar
cjhammes cjhammes is offline
Hi Larry-
7s and 8s tail sections are pretty similary, if not identical. I trimmed as indicated per my 8 plans (or so I thought) and later had to add weight. I too used electric trim and found more weight needed for proper balance. This may vary from one to another depending on how much RTV or proseal used on trailing elevator edge, process used for fiberglass tips, prime/no prime, etc. Suggest you don't trim any until all is complete and you are ready to balance. My 2 cents worth.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 06-11-2013, 09:07 AM
bret's Avatar
Yip, RTV, paint, glass work, servo, all adds weight, you will need those counter weights.
Old 06-11-2013, 06:51 PM
wirejock's Avatar
Default weight
Thanks Charlie and Bret.
I installed as is. I can always take away.
Larry Larson
Estes Park, CO
Disclaimer
Old 03-29-2017, 11:15 AM
RV7ForMe RV7ForMe is offline
hey Larry I know this thread is a few years old. but i am asking the same thing now. how did it turn out? was leaving it as is the right move?
VAF 05/2017 dues paid
RV7 - Working on empennage
Cessna Rocket 210HP - Best dang 172 Ever made!
