"Although mounting the GSU 25 to the threaded holes on the back of the GDU 4XX display is not generally recommended due to instrument panel flexing ..."
I would like to know if anybody has mounted the GSU 25 to the GDU 460 on a standard RV8 instument panel and has experienced "panel flexing"? Or the rigidity of a standard panel for that matter. If it is susceptible to any flexing in the finished configuration.
I was curious if the RV8 panel is less prone to flexing because of the narrower fuselage.
We Have one on the back of the GDU-460 and it does very well. Good place to put it. We do have a lower edge panel shelf that makes the panel a lot stiffer.
Yours, R.E.A. III #80888
Garmin G3X Support g3xpert@garmin.com
We were able to resolve this issue by using the Safe Air system for the plastic lines at this location, but Steve is very correct here with this post.
I tell a lie Roger! I've been away over the Easter period and had no access to check but the angle is actually 1"x 1.25". Here's another photo behind my panel so far.
Regards
Nathan
