Old 04-16-2017, 02:56 PM
salto salto is offline
Default MT Propeller recommendation
After supplying required information to MT in Germany here is their recommendation.
I was trying to get a four blade(cool factor only) after reading about the performance they are achieving (no real performance advantage)
They came back with 74in three blade.
Type: MTV-12-B/188-59f
+ Spinner Assy P-469-2
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 04-16-2017, 04:23 PM
mike newall's Avatar
mike newall mike newall is offline
RV14
IO-390
MTV-12-B/188-59f
Mmmmmmmmmmm
4 Blades are for the pure aero boys !
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated twice in 2017
Old 04-16-2017, 08:11 PM
johnbright's Avatar
johnbright johnbright is offline
Default Cowling
Does a three blade prop complicate cowling removal?
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, SDSEFI EM-5
Dual alt, single batt. Wiring and IP CAD files here
Newport News, Va
Old 04-16-2017, 08:27 PM
Driving '67 Driving '67 is offline
Love the look of the 3 blade prop! If you don't mind me asking, is there much of a price differential between the Hartzell and the MT prop. Any operational restrictions (ie certain rpm ranges)?
Thanks Jim
RV 14A wing/tail/fuselage done
Doing the avionics/wiring harnesses
G3X/GTN650/GTN625/GTX45R
Waiting for warm weather to do the canopy
Serial 140118
Old 04-16-2017, 09:55 PM
Current quote I have for MT is 9,700 euros plus freight.
Don't have a price on other 3 blade props.
They state that it is 29lb lighter than an aluminium one. Not sure what that would do to weight and balance.
Don't have weight yet to do W&B.
Kit 140241
Tail Feathers done
Canopy next. Phew!
Old 04-16-2017, 11:17 PM
Evolution10 Evolution10 is offline
Yes, the 3 blade does complicate cowl removal (when my hub goes, I will go back to a 2 blade). It makes it very difficult to get off, especially if you have engine extras.
Old 04-16-2017, 11:38 PM
Yes it does (though there are mods that can be made to make it not too much more difficult)
Pretty simple.... It will move the empty C.G. further aft than it it would be if a Hartzell prop. was used.
It is a pretty simple W&B calculation using the published W&B sample and the different weights for the different propellers to calculate what the difference would be.
Scott McDaniels
Hubbard, Oregon
Old 04-17-2017, 04:03 AM
Yes agree Scott just not sure if it puts it past the aft balance line as I don't have the prop weight yet. Might be a no go just not sure yet.
Kit 140241
Tail Feathers done
Canopy next. Phew!
Old 04-17-2017, 08:33 PM
Chattin35 Chattin35 is offline
Default Zero cool factor, but...
The most efficient prop will have 1 blade.
Old 04-18-2017, 01:33 AM
paul330 paul330 is offline
I have the 3-blade MT on my -10 and I can tell you it is super-smooth. Everyone who has flown behind a 2-blade prop comments. Also, there are no resonance issues so no limited RPM bands.
Yes, the bottom cowl removal is a little more difficult but not excruciatingly so. I assume the -14 has a similar arrangement. You just need to extend the gear slot and fit in a cover plate. With a tailwheel, I guess there wouldn't be an issue at all. Thinks - why didn't VANS produce a tailwheel version of the -10?
It is also, apparently, a few knots slower in the cruise, but another plus is that you get a couple of inches extra ground clearance.
Paul
Mercy Air, White River FAWV
ZU-IIZ - "Zeus"
2017 Donation Made
