Old 04-10-2017, 08:20 PM
E. D. Eliot E. D. Eliot is offline
Default Canopy - how tight?
I'm pretty happy with the fiberglass work on my RV-12 - have found that fiberglass work is kind of an art. Much to learn and I appreciate all of the posts by others here on the VAF - especially Dan Horton and the RV-14 tutorial.
I'm almost finished and have a question for the brain trust here - how tightly should the canopy fit on top of the front fuselage aluminum cover? Mine is pretty tight - actually touching the top of the fuselage aluminum sheeting that covers the avionics shelf. I think that I should make some room for the paint so do I want 1/64, 1/32, or more clearance?
Don't want wind or rain inside of the cabin and don't want to scratch the paint. As it is now, when I put the weather strip down under the canopy front, it surely would remove paint when the canopy is opened and closed - it's too tight. Please advise.
Building finally
Old 04-11-2017, 10:10 AM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
I also made mine very tight, touches paint. Just put a layer of the clear protective tape on underside and after a year no paint abrasion but I can not install the weatherstrip (canopy will not close). Without the weatherstrip I get no air leakage but probably would get water when flying in rain. So if I did over, I'd make same but probably cut a 1/16" channel in underside to fit in the strip of weatherstrip set back 1/4" or so from the contact point on the front. Probably could do now with canopy off and upside down with a Dremel sanding disc and a lot of TLC.
Scott- 2018 dues paid
Got medical back, now building a 7A.
RV-12 #120515, 319RV over 235 hours.
1st flight 12/08/15, flew SNF, Oshkosh, Triple Tree & SERFI in year 1!
RV-9A, 536 hours, sold, RV-7 sold, Kitfox sold
Old 04-11-2017, 01:58 PM
Default Thanks Scott
I really like your idea of the channel. I think that my canopy fit is too tight though. Unless I get counter intelligence from the group, I'll try to make the fit clear by about 1/64 or so. I really don't want to mess up my paint.
I really appreciate your answer, Scott. With the thousands of tilt-ups in the Van's fleet, I find it amazing that I received only one answer!!!! Amazing. Guess that I should have posted my question in the 'General" Section.
Building finally
Old 04-11-2017, 02:10 PM
PilotBrent PilotBrent is offline
That's because asking us to agree that "a tight fit is a bad thing" is too easy of a softball to hit. You've got to make it more challenging!
If you look around, many RV-12 canopies are not very flush across the top skin so its probably not a very common concern. Its just glass, so I guess you could add more layers on top for strength and then sand the underside if that helps.
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 04-11-2017, 03:12 PM
DHeal DHeal is online now
I built my canopy as per Van's plans -- keep the fiberglass layers thin -- more thickness is not necessarily better. It turned out very well and doesn't scratch the finish paint. A slight gap (@ 1/64" or less) results due to the layers of tape used during it's construction. Paint thickness reduces this clearance a very little bit. I installed Van's "reverse V" weather stripping along the front edge of the canopy fairing -- it works fine to seal out air and light rain (I haven't tried it in heavy rain yet.). Build on and don't worry.
EAA #23982 - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 635+ hours (as of May 2018)!
VAF donation through June 2018.
Old 04-11-2017, 09:30 PM
Mine is tight and actually wears through the paint on the avionics ba cover at a few points. I still like the tight clearance as opposed to wind and rain!
Old 04-12-2017, 08:27 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
I like your suggestion of the clear protective tape...like the kind they use to prevent rock damage on autos.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 04-12-2017, 12:49 PM
If built as suggested (with enough gap allow for installing the fwd seal that is supplied in the seal kit, the canopy) and the entire seal kit is installed as directed, the canopy can be water tight in heavy rain (specific flight testing was done in actual heavy rain conditions while the seal kit was developed and tested)
Scott McDaniels
Hubbard, Oregon
Old 04-12-2017, 06:59 PM
I used the UMV? as specified for flaps in other RVs but found Gorilla thick clear repair tape 2" by 27' for about $15 as sold at Lowe's/Home Depot aviation supply to stick better, readily available and much cheaper.
