Old 12-24-2016, 11:01 AM
Adam Wright's Avatar
Adam Wright Adam Wright is offline
Tosten makes a nice looking stick for the 14. Has anyone asked them to consider doing one specifically for the 8? Seems like they have the capability.... I would be interested.
Adam
RV-8 Builder #83611
Old 12-24-2016, 11:18 AM
Bill Dicus Bill Dicus is offline
Default Stick bending
We did the cut and weld procedure on my RV-8 stick with the Tosten grip. It works well, but the stick is so far back in the flare that my cuff deficient shoulder doesn't work as well to control the flare as it did with the short stick. I still think it's an improvement but might require some fine-tuning. Will try to post some pics. We used a PVC dummy stick to plan the cuts.
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 12-25-2016, 08:22 AM
bifft bifft is offline
Originally Posted by Blain View Post
Pack it with sand, cheap pipe bender. No cuts or welds.
I did the same thing, only I didn't have sand. Filled with water, froze it and then bent. Ended up with a little bit fewer wrinkles than you have there.
Old 12-26-2016, 09:10 PM
Blain's Avatar
Blain Blain is offline
Interesting. I'll keep that technique in mind if I ever do another.
I'm more comfortable with wrinkled bends than welded miters.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2018(my reminder)
Old 04-05-2017, 07:25 PM
MCingari@gmail.com MCingari@gmail.com is offline
Default Stick Bending service available again
I have passed the torch to Karlo Gatdula, karlo.gatdula@gmail.com
I have provided him the die and equipment I use to bend the sticks.
Please send him an email if you would like your RV-8 front stick bent.
Mike
MRC
Old 10-18-2017, 09:34 AM
Saville's Avatar
Saville Saville is offline
Default How much did you have to bend?
I have an RV-8 and the stick is too low for me. Also I'd like to install an Infinity Grip.
I've started on this project and I made a stick out of 3/4" PVC to get an idea of about how much the stick has to be bent.
The centerline of the present grip is about 2" beyond the edge of the instrument panel.
I found with my PVC mock up that to get the infinity grip higher and fully in front of the instrument panel, I need to bend it such that the new centerline (above the two bends), is a full 4" aft of the main stick centerline (below the two bends).
This seems like a lot. Is that what everyone else, who has implemented the bent stick has found?
Flying RV-8 N880BC
Double the 2017 Dues - happily paid.
Old 10-18-2017, 01:34 PM
Scott Hersha Scott Hersha is offline
You probably don’t want a 4” offset, unless you’re incredibly skinny - your belly could be in the way attempting to get the stick all the way back. My first RV8, I cut and welded a 2” offset and found this to be about right with an Infinity grip. My current RV8 will be offset too, probably just like before, although I wish I could find someone to bend it.
Scott Hersha
2001 RV-6 - sold 2005
2008 RV-8 Fastback - Sold 2016
RV-14 Wings - sold 2014
RV4 - Sold
Cessna 182RG - flying
New RV8 - Under construction
Cincinnati, OH/KHAO
Old 10-18-2017, 01:50 PM
Saville's Avatar
When fully forward, was the top of your Infinity Grip in front of the instrument panel and higher than the lower edge of the panel?
Flying RV-8 N880BC
Old 10-18-2017, 02:26 PM
No. The bend in the stick allows you to keep it a little longerand avoids contact with the gear tower cross brace, but it still goes under the panel - just slightly in my case with my infinity grip. If you want to make it long enough so that it’s above the bottom of the instrument panel, you’ll need that greater (4”?) offset, but you will probably need to also move your seat back a little. A long stick is good, but you’ll need to pay attention to geometry and other related consequences. Whatever you change, make sure you have full unobstructed control movement and authority.
Scott Hersha
RV4 - Sold
Cincinnati, OH/KHAO
Old 10-18-2017, 02:39 PM
Saville's Avatar
I already checked the belly clearance
Thanks!
Flying RV-8 N880BC
