Old 03-02-2017, 04:12 PM
TomVal TomVal is offline
Originally Posted by Slane View Post
Does anyone know the weight of the replacement nose wheel fork?
Shane,
Here is the information:
http://vansaircraft.com/pdf/Notifica...2016-09-21.pdf
Regards,
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 03-02-2017, 10:28 PM
Slane Slane is offline
Originally Posted by TomVal View Post
Shane,
Regards,
Perfect! Thanks.
Scott Lane
Hillsboro, OR
RV12 Completed & Flying 2013
#120043 N728SL
VAF paid 2018
Old 03-15-2017, 06:51 AM
todehnal todehnal is offline
Well, after reading all of the post regarding nose wheel fork issues, I decided to order the updated fork, even though after 250 hours, mine still looks good. I have an early build, (120119) but I like to keep up with the changes that make sense. Just received the new style fork. Man, that is one UGLY looking assembly. I'm now arguing with myself about installing it. It's really ugly, and I don't think paint is going to help.......Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 03-15-2017, 07:05 AM
SgtZim SgtZim is offline
I'm very curious how you don't get a prop strike when the nose gear collapses? Was it a partial or gradual bending?
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 03-15-2017, 11:37 AM
Raymo's Avatar
Raymo Raymo is offline
Only the fork "collapsed." The gear leg remained intact but threads were damaged.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 03-29-2017, 10:53 PM
gossend gossend is offline
Default Upgraded fork - just do it?
Can i upgrade the fork and simply reinstall my current nose wheel pant?
OK I hear it's ugly. So what? Cant I just cover it with the wheel pant?
Is this really a big deal?
I dont get it.
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with G3x Touch
Old 03-30-2017, 06:51 AM
John-G John-G is offline
I dont get it.
Dick,
I asked the Mother ship about replacing the old style nose fork with the new improved version. My take away is that older wheel pant kits used on the original fork can be installed on the new fork ... HOWEVER, the mounting is different so it will leave you with unused holes that will need to be plugged likely requiring a repaint.
I was asking because I have the RV-12 wheel pant kit, but it is not installed yet ... so I called to find out should I install the pants now on the old fork and replace the nose fork at a later time could I reuse the wheel pants? After hearing that I could reuse the wheel pants but it would need the old mounting holes plugged or patched, (likely requiring repainting) it prompted me to order the new fork now and install it when installing the wheel pants.
Just received the new nose fork ... it is much beefier than the old fork. Van's did not skimp on the metal ... it is made WAY stronger than the old fork.
Also, because the wheel pant mounting is different on the new style fork, it requires some different mounting hardware and brackets which Van's has ... so be sure to ask for that if you are using an older wheel pant parts kit on the new fork.
Happy flying,
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 03-30-2017, 07:09 AM
Captain Avgas Captain Avgas is offline
Originally Posted by Keldog View Post
The entry for this annual inspection as well as almost all of the previous simply have a standard blurb indicating that all relative SB's have been complied with. Only once in the logs do I see a specific SB# called out. Is this standard? Or is it even practical to individually list all of the relative SB#'s?
Of course it is practical to individually list all of the relative SBs in the aircraft logbooks. A "standard blurb" indicating that all relative SBs have been complied with, without referring to any relevant SBs, is absolutely meaningless. How does anybody examining the airframe logbook determine if any particular AD or SB has actually been dealt with. I would guess this may be illegal. At best it is incompetent. In this particular case the nose wheel may have been inspected in accordance with the SB at the last annual...but it may not have. How can you know in this instance.
Regards
Bob Barrow
RV7A
Old 03-30-2017, 10:18 AM
Anyone have a picture of the new fork?
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 318
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 03-30-2017, 10:33 AM
DHeal DHeal is online now
See Van's updated drawings at:
http://www.vansaircraft.com/pdf/revi...2/RV-12_35.pdf
http://www.vansaircraft.com/pdf/revi.../RV-12_36A.pdf
EAA #23982 - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 620+ hours (as of Apr 2018)!
VAF donation through June 2018.
