Old 01-11-2020, 09:28 AM
dromuald's Avatar
dromuald dromuald is offline
Default sniffle valve required?
I have an RV 8 with an IO-360 injected motor. I bought the plane from the builder 7 years ago. At my recent condition inspection it was suggested that I install a sniffle valve on the bottom of the intake sump. That port is currently capped off with an AN fitting. This motor has 850 trouble free hours on it over the course of 17 years. My question is this - have I been lucky operating this motor or is the valve not really required. I realize it is used to drain the sump of residual fuel and or oil. If there is no drain does this fuel just get scavenged back into the intake system? I guess my point is why should I mess with success?
___________________
Dave Romuald (FFC)
RV-8 655CL
Old 01-11-2020, 10:12 AM
Bavafa Bavafa is offline
It is not required but it does help very much and it is a great addition for how little they cost or the ease of installation.
It helps drain the excess fuel in the sump when the engine is not running.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-11-2020, 10:14 AM
bjdecker's Avatar
bjdecker bjdecker is offline
It would be interesting to measure how much residual fuel, oil, stuff, has accumulated in that sump after all these years...
Brian Decker
Retired Firmware Guy and Airplane Builder
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 01-11-2020, 10:28 AM
BillL BillL is offline
Yep, next oil change when the engine is hot, take out that plug. If you feel lucky, don't put a pan under it. Mine drips sometimes, especially if flown rich and doing approach practices.
DanH does not have one either . . .
Bill
Prepping for Paint
No Photo? => PM me.
Old 01-11-2020, 10:52 AM
Super Moderator
I've done inspections on those without them. Some nasty stuff comes out of that drain when the plug is pulled. It's a combinations of fuel and oil that drains back through the intake tubes when the engine is shut down.
Vic
Vic Syracuse
Kitplanes "Checkpoints" monthly column
www.Baselegaviation.com
Old 01-11-2020, 03:21 PM
JonJay's Avatar
JonJay JonJay is offline
Probably should note to casual readers that a sniffle valve is for horizontal injection, not vertical.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-26-2020, 08:53 PM
rswalden's Avatar
rswalden rswalden is offline
Hi, Torque....
I installed mine when the engine was new and haven't had any issues. Easy, cheap installation that takes less time than reading through this thread. Just do it!
Waldo
Bob Walden (Waldo), CFII-ASMEL
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 600+ Hours
RV-12 (Sold)... RV-12 Transition Training
EAA/AOPA/Vans Air Force 2020 Supporter
