Old 01-11-2019, 01:37 PM
LeMar LeMar is offline
Default FS: MT Prop Governor
MT Part #: P-860-4, S/N 11G613G.
Appears new as it still has some grease on the mounting flange. Came from a project I bought from an estate.
$750
LeMar
Old 01-11-2019, 04:05 PM
schaplerrh schaplerrh is offline
I might be interested. Let me check model number on my governor and then I'll send you a PM. Robert
Old 01-11-2019, 10:30 PM
fasilpereira fasilpereira is offline
Second in line.
Old 01-12-2019, 07:24 AM
LeMar,
Do you have any paperwork for the governor? Do you know when it was manufactured? I believe that these governors have a 72 month tbo.
Thank you,
Fabricio
Old 01-12-2019, 08:09 AM
I do not have any paperwork on he governor.
I've looked through the Service Bulletins and Service Letters on the MT Website and have not found reference to a TBO on this model and serial.
Old 01-12-2019, 08:24 AM
Ok LeMar.
I did some research on the MT website and here is what Iíve found:
From the governor manual, page 5, the first 2 digits of the serial number are the year of manufacture. So, yours was made in 2011.
From the SB-1R3, page 10, the TBO is 2000h or 72 months.
https://www.mt-propeller.com/pdf/sbs/sb1r3.pdf
If I got it right, according to the same document, page 1, the TBO starts with the installation on the aircraft.
However, if the installation is later than 24 months after new assembly or overhaul and proper storage provided, the TBO automatically starts after this 24 months, up to maximal 96 months calendar time.
If Iím correct, your governor will be due on 2025 (2011 + 8 + 6) if it was never run and installed.
Iíll think about it. Since Iím still building, I donít want to start counting TBO now.
Best regards,
Fabricio
Old 01-12-2019, 11:06 AM
MConner MConner is offline
Anyone have a link to an English version? I donít speak Deutch.
Bought not built
EAA 180
48X
Old 01-12-2019, 12:11 PM
Default MT Governor
Not the P# for my propeller so I will pass. Thank you. Robert
Old 01-13-2019, 03:40 AM
Mark,
The MT website link is:
All the documents on the website are both in Deutsch and English.
The P-860-4 is usually used on the O-320/360 with rear governor pad.
Regards,
Fabricio
