Old 01-05-2019, 07:33 AM
Electrogunner Electrogunner is offline
Default Anti splat prop wrench
I have a new never used anti splat ultimate prop wrench for sale. Ultimately I can’t use it because it will not fit behind my spinner backplate. I had to make a custom wrench with an angle. $60 includes shipping CONUS. PM or email. Thanks
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Final assembly
Old 01-05-2019, 07:41 AM
Originally Posted by Electrogunner View Post
I have a new never used anti splat ultimate prop wrench for sale. Ultimately I canít use it because it will not fit behind my spinner backplate. I had to make a custom wrench with an angle. $65 includes shipping CONUS. PM or email. Thanks
I don't need the wrench, but am curious about what you did differently so the wrench won't fit?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-05-2019, 08:18 AM
Default Yes...
What prop/spinner are you using?
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 01-05-2019, 08:38 AM
Whirlwind 375RV 3 blade with their 15"spinner
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Final assembly
Old 01-05-2019, 08:45 AM
Default prop/spinner
Would you have a picture? I was going to buy that wrench for my MT 3 blade...
Bob
290 HP Barrett Hung
Wiring...
Old 01-05-2019, 12:47 PM
Hi Bob,
Send me an email to electrogunner@gmail.com and I can send you a pic of the wrench. The wrench is straight and it's thicker than a standard wrench. That is why I can't use it. My buddy has the MT 3 blade on his with the SP cowl and he has alot more room then mine. Mine was a challenge to safety too.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Final assembly
Old 01-05-2019, 03:42 PM
Default sent
email sent...is the wrench still available?
Bob
290 HP Barrett Hung
Wiring...
Old 01-05-2019, 06:33 PM
Scott Hersha Scott Hersha is offline
The anti-splatt prop wrench works fine on a Whirlwind as long as you bolt the prop on before installing the backplate (split model). If you have a single piece backplate, then youíll obviously have to install it first. In that case, you may need some sort of Ďmodifiedí torque wrench - I havenít done one of these. The single piece spinner backplate/bulkhead would be easier to install with the prop not installed, but the prop install on the engine would be a little more difficult requiring a different wrench.
SH
RV-8
Cincinnati, OH/KHAO
Old 01-05-2019, 07:10 PM
Bob,
I replied to your email with pics. Let me know if you can use it.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Final assembly
Old 01-05-2019, 07:13 PM
Yes I have a one pc backplate that requires install ahead of the prop. Which makes it a bit of a challenge. But doable with some modifed tools.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV
Garmin G900X
Final assembly
