Old 02-23-2015, 06:35 PM
David Z David Z is offline
That looks really nice. I'm planning on a similar panel, your just much farther ahead of me
RV-8 Empennage Passed Pre-Close Inspection
Working on Wings
83126
Donations current
Old 02-23-2015, 06:45 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Thanks
Just wired up and finished the SL-40 install along with the GTX-327....everything works as it should. Really like the HSI function on the D-180 with the G496.
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
2018 donation contributor.
Old 03-08-2015, 06:14 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Default Fired up the panel today...
This is Bob Lund's RV-8 that I'm helping wire. Panel was done by Aerotronics. So we got it installed today and got the battery connected so we were able to turn the master on, avionics master, activated the start relay and got the starter-engaged light to come on. One wire at a time, lots more to do!
The G3X Touch is nice! I see an upgrade in my future.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Helped build Bob Lund's airplane)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 03-08-2015, 07:22 PM
MNAv8or MNAv8or is offline
Hey Pat, I'm curious why you elected to install a starter engaged lamp on the panel? I have never seen this before except in turbine aircraft as there is a delay between starter engagement before the propeller begins to spin. Any particular reason for a piston airplane?
Patrick Townsend
A&P/ IA - EAA Tech Counselor
Vans RV-8 Fuse on order
Cessna 195 N195F - Currently restoring.
Stinson 108-1 N97842 - sold
Cessna 185F N8710Z - sold before restoration began
Vans RV-8 N130X - Rebuilt and sold
Cherokee 180D N7990N - Rebuilt and sold
Cessna 172 - N4296F - Rebuilt and sold
Old 03-08-2015, 07:28 PM
Pat Hatch's Avatar
Pat, yes, it's just to make sure the relay disengages. Stuck relays are not good in this situation.
Pat Hatch
RV-7 (Sold)
Track Me
Old 03-08-2015, 07:34 PM
True but in 12 years of working on airplanes everyday, I have never seen that happen. It's a good idea though! That is why I love Experimental aviation! See an idea and put it to use.
Patrick Townsend
Old 03-08-2015, 08:04 PM
Pat Hatch's Avatar
Agreed, but it can happen. The way I look at it is you have the information sitting right out there on the "I" terminal of the relay, why not use it? Just one wire. But I'm with you, it's great that we have the freedom to make the choice, gotta love it!
Pat Hatch
RV-7 (Sold)
Track Me
Old 03-08-2015, 09:36 PM
cajunwings cajunwings is offline
Default Starter Engaged
I've seen this happen 3 times where the starter solenoid failed closed. Once was after a start and was obvious due to noise and pegged out ammeter. The others were before start. Anytime the battery master was on the prop was turning. Always a good idea to clear the prop arc of people, objects, tow bars ect before turning on the master. My plane will have a starter engaged light installed.
Don B
RV 9 Rebuild in Progress
Old 03-19-2015, 05:37 AM
Walt's Avatar
Walt Walt is offline
Our latest RV8 panel upgrade..
Before...
After...
G3X, dual ADAHRS, GMC305, Auto Pilot, GTN650, GTR200, GMA240, AOA, Heated Pitot, GRT Mini X.
Complete electrical system re-wire including new switches and breakers and B&C back up alternator.
Equipment and Panel CNC from Stein.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-19-2015, 06:00 AM
Default Nice!
Pretty slick looking panel there Walt!
RV-8 build
DONE!
C-GLOV
