Temperature and speeds programming
woodsideraff
Does anyone know where to get the programming numbers for the io 390 and rv-14: yellow arc ranges, red lines, etc. I have a few of them, but it would be nice if someone has already collected them in one place for reference.
The IO-390 Operator's manual gives some more numbers:
Fuel pressure (PSI): min 14 / max 45
Oil pressure (PSI): max 95 / min 55 / idle 25 / Start 115 (I would set a green range of 55 to 95 and amber from 25 to 55 and 95 to 115)
Max oil temp 235?f, desired oil temp 180?f (I read this as the green range is 180 to 235)
Max RPM for the IO-390 is 2700, but your propeller may limit this and may have certain "avoid" ranges.
