Old 11-26-2019, 06:38 AM
Pittsartist Pittsartist is offline
Originally Posted by skylor View Post
Turn radius per G in level flight is purely dependent on speed and nothing else.
Skylor
Quite right........I did'nt really put over my point very well.
I suppose what I was trying to say was that the RV seems to induce less drag and "slips" less when pulling G in a turn. This is reflected in less loss of speed and the aircraft seeming to "hold" the turn radius better, purely subjective and only from my perspective as the pilot of the RV.
NOTHING is Foolproof .... To a sufficiently Talented Fool
Old 11-26-2019, 10:21 AM
skylor's Avatar
skylor skylor is offline
If the RV "seems" to turn tighter, what you are probably seeing is a greater loss of speed in the RV. Remember, the low aspect ratio wings of the RV have a lot of induced drag at high angles of attack while the One Design with its thick tapered wing along with its lighter weight should tend to fare a little better in hard turns. At constant "G", the slower the speed the tighter the turn radius.
Skylor
Skylor
Old 11-27-2019, 07:13 AM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
Originally Posted by rph142 View Post
The original owner is selling his 1/4 share. I just bought into it this summer and will need at least a few years to scratch the itch. Youre right about the view straight down being better than the RV series. You sit well behind the trailing edge in the Extra.
Thank you very much Rob. I hope to see you at contest sometime!
Jerry Esquenazi
RV-8 N84JE
Old 11-27-2019, 08:42 AM
sandifer sandifer is offline
If the RV "seems" to turn tighter, what you are probably seeing is a greater loss of speed in the RV. Remember, the low aspect ratio wings of the RV have a lot of induced drag at high angles of attack while the Extra with its thick tapered wing along with the bigger prop and more power tends to fare a little better in hard turns. At constant "G", the slower the speed the tighter the turn radius.
He was referring to the One Design rather than an Extra. The wing of a 1D is barely more efficient than a baseball bat.
Old 11-27-2019, 09:37 AM
skylor's Avatar
Default Oops
Oops, my bad. So the One Design has a weight advantage over the-7 and the thick entry of it's wing should still work pretty well pulling G's even if it's lousy in cruise!
Skylor
