Old 09-20-2019, 04:28 PM
pilot28906 pilot28906 is offline
Default Van's Seat Foam?
I am thinking of getting the Van's seat foam and having them covered locally. For those of you who have used the Van's foam:
1) Do you cover each piece individually (wedge, booster, seat, and back)?
2) Is the seat cut out for the crotch strap seat belt?
John
RV7
John Johnson
Murphy, NC
RV7
Old 09-20-2019, 04:41 PM
N941WR's Avatar
N941WR N941WR is offline
I had mine covered individually.
That way I can adjust the seat height based on my passenger. Really tall guys get just the long cushion, short guys get the wedge plus an extra inch or two.
I fly with just the wedge and the long piece.
They are very comfortable on long flights.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-20-2019, 08:10 PM
jpowell13 jpowell13 is offline
Default Flightline
Have you talked with Flightline Interiors? As I recall, you can have foam shipped straight to them and they will cover foam at a very reasonable cost. John
Old 09-20-2019, 08:55 PM
Electrogunner Electrogunner is offline
Default Foam
Alot of shops will do custom foam work for you cheaper than the vans foam sets. That way you can customize the feel of the seats. My seat guy took one look at the vans foam and said " you will not like it". I had him do different density foam and glad I did. 4 + hr legs are no problem.
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
First Flight 2/14/2019
Old 09-20-2019, 09:49 PM
You should know that in the -10, the pilot sits on top of the spar carry-thru. In the event of a vertical impact, there is little crush space available. The Vans foam was specifically designed by Oregon Aero to provide controlled crush space, to protect your spine.
I find the Vans seats to be perfectly okay for long flights. If itís cold, theyíre a bit firm until things warm up.
Old 09-21-2019, 08:47 AM
To each his own. Iím sure they did extensive testing on the memory foam that they use. Yes it is firm when cold , but once it warms you might as well be sitting on the spar carry through. I still stand behind my choice.
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
Old 09-23-2019, 07:39 PM
Thanks guys for the info.
How does the Van's foam compare to the foam that comes with the seats from Flight Line Interiors?
John
John Johnson
Murphy, NC
RV7
Old 09-24-2019, 05:09 AM
N941WR's Avatar
John
No idea how it compares but it is very comfortable.
But after this record breaking flight, I asked Ron what seat cushions he had and when he said, "Van's," I placed my order and have been very happy for the last 900 hours
Bill R.
SC86 - Easley, SC
