Old 09-20-2019, 06:54 AM
RV6_flyer's Avatar
Originally Posted by phapp View Post
I was planning on using markings on the tape to indicate degree of flap extension.
Which one of the tape options would be best for marking / painting / other?
I have manual flaps. I can reach back with my right hand and feel what detent the flaps are in.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-20-2019, 02:36 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Teflon tape
I used Teflon tape on the underside of the overhang and nothing on the flaps. No problems to report after 5 years and 600 hours.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 09-20-2019, 07:30 PM
Jpm757 Jpm757 is offline
I used the fuzzy side of Velcro on the bottom of the top wing skin overhang. No issues.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 300+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 09-21-2019, 02:37 AM
Breezy Breezy is offline
David,
I used the clear protector like the 3M product mentioned above applied to the leading edge of the flap. Then applied a strip of felt to the underside of the wing skin. Spruce sells 1 1/2" felt adhesive backed. Been flying the aircraft for 3 yrs and no scratches.
Breezy
First offense RV-8; N594WR; 80594 (time served)
ECI TITAN IOX 360 A1A9N, G3X
Repeat Offender: 83137 (Flying 10/16)
N837DW; Superior IO 360; G3X Touch.
Exceptional Aircraft Award, Sun N Fun 2017; Best Homebuilt, Mid-Eastern Regional Fly-in 2017.
One More Time: 140359, -14 in process, IO-390 (Maybe)
KHAO (Hogan Field)
Old 09-21-2019, 04:58 AM
plehrke's Avatar
plehrke plehrke is offline
I have the UHMW tape and put sharpie marks at each flap setting before first flight, mainly for quick indication during phase 1 flight test. Did not expect marks to last very long. 13 years later and 900 hours and the marks are still visible and I use them them to verify flap position still. I vary when I put in second notch of flaps depending on pattern entry and speed (I have a fixed pitch prop so need more attention to speed reduction) so quick check when turning final let’s me know how many clicks I got to get full flaps by the time I cross the fence. I like steep approaches on final so gives me decision point to slip, add/pull power, or add that extra notch of flaps if I have it.
Philip
RV-6A - 13 years over 900 hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
