Old 09-20-2019, 10:00 PM
johnbright's Avatar
johnbright johnbright is offline
Originally Posted by MCA View Post
I haven't seen the Z-14 in common use for a while. It was used for IFR panels in exp aircraft a while back (like 20 years ago), but these days we have ways to provide backup and redundancy using a simpler single main bus architecture.
That can be accomplished using a combination of EFIS with built-in battery, essential bus architecture, and/or battery backup modules (Like the IBBS).
You haven't mentioned if your RV-10 is for IFR or VFR use.
My suggestion would be to look at a simpler architecture then design in the needed level of backup for your mission.
What if one is using EFI with no mechanical fuel pump?
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, dual SDSEFI EM-5-F
Schematic and other electrical related files
Instrument panel CAD jpg images
Construction Photos
Newport News, Va
Old 09-20-2019, 10:48 PM
MCA's Avatar
MCA MCA is offline
A single main bus works for most conventional aircraft, both VFR and IFR, with varying levels of backup and redundancy depending on your mission.
If you are running an electrically-dependent engine or some other alternate configuration, the manufacturer of those systems typically specifies the needed electrical system and you should follow that.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
