Old 09-13-2019, 08:41 PM
WingsOnWheels WingsOnWheels is offline
I installed the echouat-ext as well. Mine is tied to the dynon for alt, and the gtx-330 for squawk via the uavionics serial multipler they provided at no charge. I have the box and antenna mounted in the right wing access panel. PAPR report came back clean. I am using a samsung galaxy tab A with the adventure pilot software. I had no problems with the configuration and the traffic display is working great. Everything connects right away.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec), but donated early in Sep'19.
Old 09-13-2019, 09:01 PM
Brdog42 Brdog42 is offline
Colin,
The WiFi connection is good from the wing location? How strong is the signal? That wing panel sounds like a great location if the WiFi is sufficient.
Tim
1973 A150L sold
RV-6A restoration in progress
KCHD AZ
‘’’’’’’’’’’__|__
*>—O-(_)-O—<*
Old 09-14-2019, 04:50 PM
Originally Posted by Brdog42 View Post
Colin,
I dont recall how many bars offhand, but more than enough. I havent had any wifi issues with my phone or tablet, on the ram mount, or in my lap.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 09-14-2019, 05:13 PM
redhawk redhawk is offline
Default Uavionix Echo/Skyfyx
Installed my Echo/Skyfyx-Ext. Install straightforward as well as configuration setup but ... My flight report came up with “Baro Alt” failure 2 flights in a row. I lowered “Transponder Threshold “ in Advanced settings to 1475 but got same exact result.
Has anyone had this issue and found a way to correct the error?
Thanks out there.
Old 09-14-2019, 05:28 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default I ended up with TXP threshold of about 1300
and everything has been great!
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 09-14-2019, 06:38 PM
Default Echo
Ok will give it a try !
Old 09-14-2019, 07:39 PM
BH1166 BH1166 is offline
Default KT76A. Threshold move down to 1100
Before I can get a squawk to show on monitor.
Butch
RV6A Purchased N72TX
2020 Dues Paid
Old 09-15-2019, 06:25 AM
Skysailor Skysailor is offline
Default May have to go lower than 1475
I just helped a friend solve the BARO ALT error being the only fault. Discussion with tech support at Uavionics revealed you can continue to lower the sensitivity number. There are cases it needed to be as low as 900 but that is uncommon. Unfortunately, the other issue to be considered is your Mode C might be at fault. We found his blind encoder to be faulty. Replacing that solved the issue even with the sensitivity back at 1500. Your Mode C can be checked by asking for a verification of altitude being broadcast from any ATC facility.
RV4
Old 09-15-2019, 06:57 AM
Default Echo
Think I’ll lower it one more time from 1475 to 1300, then consider a encoder issue. I wonder how many times you can fail a Performance Report before the FAA sends out a nasty- gram ?
Old 09-15-2019, 12:04 PM
donaziza's Avatar
donaziza donaziza is offline
I was just told to lower mine to 1100. This got rid of the mode 3A problem, but I still have "Baro Alt". Will take the advice on calling ATC for an actual altitude vs what my 327 is saying. We'll see.
