  #951
Old 01-07-2019, 04:34 PM
9GT's Avatar
9GT 9GT is offline
Fabricating a plug for a new snorkel. It will be removable to ease the difficulty of removing/installing the lower cowling with a three blade prop, and it will also house a custom FAB. I don't care much for the Van's FAB bolted to the bottom of the fuel servo. For experimental purposes, I am going to embed a copper tape VOR antenna in it and see how well it works since I already have the materials on hand. No big deal if it doesn't work well. I will just go with my original plan of an Archer style wing tip VOR antenna.
[IMG]fiberglass 3 by David C, on Flickr[/IMG]
David C.
Howell, MI
RV-10: #41686 Under Construction
RV-9A: #90949 Under Construction
RV-10: #40637 Completed/Sold 2016
Cozy MKIV:#656 Completed/Sold 2007
"Donor Exempt" but donated through Dec. 2020
Old 01-08-2019, 08:21 AM
rocketbob's Avatar
rocketbob rocketbob is offline
Removable scoop is a game changer. You will find that with a removable scoop that it will be rare that you will have to remove the lower cowl.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N9187P PA-24-260B Comanche, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 01-08-2019, 08:45 AM
9GT's Avatar
9GT 9GT is offline
I agree Bob. I put one on my RV-10 and loved having it. I really enjoy fiberglass work also.
David C.
Howell, MI
Old 01-27-2019, 03:32 PM
dwranda dwranda is offline
Default James cowl update
Here's a few pics of the progress. I still have work to do on it, but it's coming along. It was pretty cool to see it on the plane and to be able to open the oil door and take out the dip stick.
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Jan 2020
Old 01-28-2019, 10:52 AM
Fhuber's Avatar
Fhuber Fhuber is offline
Beautiful work. It looks great!
F Huber
RV-7A flying
2019 Dues paid
Old 02-05-2019, 05:55 PM
Av8torTom's Avatar
Default FlyLeds
Finished assembling my FlyLED, "The Works". This is the first time I've had one of the wing-tips outside in the dark. Paul at FlyLEDs was a BIG help. Pretty impressed.
https://photos.app.goo.gl/123Apm9HwNmjvVbX7
RV-9A (empennage completed, both wings completed, fuselage and finish kit completed, engine hung, working on panel and wiring)
N677AT reserved
Superior XP O-320, 160HP
Old 02-06-2019, 02:30 AM
GeoffP's Avatar
GeoffP GeoffP is offline
Tom,
I'd be keen to know if you had problems fitting the lights into the wingtip fairings? I know that Paul at FlyLEDS has said they can be tricky to fit, and may need a fair bit of trimming. My interest lies in the fact that I've already built my flyLEDS kit, and my wings are on order, so I'll be going through this in a few months.
The lights are **** bright, even testing with a 9V battery you couldn't look at them for more than a second or so.
RV-9, Tail Feathers done, Wings over halfway done
Old 02-06-2019, 07:45 AM
Av8torTom's Avatar
Goeff, it's a bit tight. I had to trim the PC boards a bit to make them fit. I used a belt sander mounted upside down on my work bench. That was a no brainer.
The biggest challenge was getting the mounting screws with the springs on them in place. Not a lot of room to get your fingers in there and I sent more than one spring flying across the shop . I replaced 2 of the short 6-32 mounting screws with longer ones. That made adjustments a lot easier. I used automotive double sided foam tape to mount the outward facing board to the wingtip - seems VERY solid. Once the forward facing wingtip surface is cut away for the landing lights, there's not enough surface area for foam tape so I used 3 nutplates and screws. Plan carefully where you want to place those nutplates so they don't interfere with anything. All in all I'm very pleased with the result, and they sure do seem bright.
N677AT reserved
Old 02-07-2019, 03:21 AM
GeoffP's Avatar
Thanks a lot Tom!!
Old 02-08-2019, 07:08 AM
ty1295 ty1295 is offline
No pictures, but I went on a bit of a spending spree the last 2 weeks ordering everything to finish up my 9A.
Engine paid in full now, due mid march, prop end of march, cowl/baffling in enroute from vans, exhaust ordered, and Dynon equipment is waiting for me to pick up at UPS in about an hour.
Time to get to assembling everything now.
Jeff Scott
RV9A First Flight 9/30/19
www.smokeonaviation.com
