Old 07-02-2019, 05:30 AM
Dustyone Dustyone is offline
Default Flyleds 7 Spot HID Replacement
Paul at Flyleds has released a 7 Spot LED drop in replacement for my old HID's that are currently in my RV-10.
They can only be fitted by removing the wing tip.
The old HID's coming out,
The new Flyleds mount straight in the old Duckwork mounts,
The new heat-sinks are a work of art ,
These lights are crazy bright at 8400 Lumens each !
This is a single light shining on my neighbours hangar,
The new lights are an instant MASSIVE upgrade to my old HID's however ever since the RV-14 came out with its large light cutout, I had wondered what they would look like on the RV-10. The standard Duckwork template was for an older and smaller light and restricts all of the good photons of light from Flyleds massive 7 spot.
Top of the leading edge with the NEW Flyleds.
The RV-14 template over my wing,
It was time to order the RV-14 parts from Van's and get out the Dremmel !
With the new RV-14 lenses and retainers, it was a simple job to mark out and CUT INTO MY PAINTED WING ! ( Did I mention measure twice cut once ! )
to be continued.....
Ashley Miller
RV-10 #40597
Dual SDS CPI
http://www.vansairforce.com/communit...d.php?t=140051
Airflow Systems Air-Con
http://www.vansairforce.com/communit...4&postcount=15
VH-XTE 600hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
Old 07-02-2019, 02:31 PM
Default Part 2
The new install was an easy upgrade,
The finished results were way beyond my expectations...
Taxing at YRED ,Redcliffe Australia,
Lining up on 07
On final for 07 with a crosswind.
I was surprised how dificult it has been to get good night time photos with an iphone. I am hoping to get some better ones next week.
Ashley Miller
RV-10 #40597
Dual SDS CPI
VH-XTE 600hrs +
Redcliffe,Brisbane
Australia
Old 07-04-2019, 05:34 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Seriously folks...........YOU WANT LIGHT????
THESE ARE THE ANSWER
GAME, SET & MATCH
Add these to the Works pack (launched this time last year) and you will be like an airliner for light.
This https://flyleds.com/products/#!/The-...651/category=0
PLUS THIS
https://flyleds.com/products/#!/Seve...915/category=0
Just do it.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 07-04-2019, 10:03 PM
the last photo is almost unbelievable.
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 800+ for all
www.rvplasticparts.com
Old 07-05-2019, 07:49 AM
N42AH's Avatar
N42AH N42AH is offline
Default RV-10 Wing Tip
Is it small enough that it could fit in the wing tip of the RV-10 as opposed to leading edge? In my case, I have a 15 gal aux fuel tank in the way.
Steve Crimm
Gilbert, SC
Based - 9SC
RV-10 N42AH
RV-9A N42AH - SOLD
Europa Monowheel XS N42EU - SOLD
BH-206B3 N42AH- SOLD
BH-206B3 N43AH - SOLD
Track N42AH/ N1FLY
Old 07-05-2019, 11:51 AM
tims88 tims88 is offline
Did the leading edge kit you ordered from Van's include a bracket for mounting the light as well or did it just include the lens and the parts to mount the lens? I know you already had the Duckworks kit but I'm thinking about putting this in the RV-10 leading edges I am about to build and the 'LL LENS KIT RV-10' on the Van's website sounds like it may not come with the bracket for the light.
Tim
Arvada, CO
RV-10 In Progress
https://www.instagram.com/n715tm/
https://timsrv10blog.wordpress.com/
Old 07-05-2019, 01:44 PM
Hi Tim,
The parts you will need from Vans are,
2 x W-00014 RV-14 Lens
4 x W-00018 RV-14 Lens Retainer
8 x K 1000-06 Nutplates
2 x Round Lampless Kit from Duckworks Aviation , I think you can order just the bracket as you will not use the smaller lenses.
I'll do some measurements next week of the cut out.There is no template that I know of , i just worked it out based on a local RV-14
Ashley Miller
RV-10 #40597
Dual SDS CPI
VH-XTE 600hrs +
Redcliffe,Brisbane
Australia
Old 07-05-2019, 03:56 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
What wire guage is needed for these lights out on the wing of a -14?
Thx
Rob Lasater
Rv-14 still workin, but getting close
Paid Dec 2019
Old 07-05-2019, 05:43 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
Hi Steve.
These area PAR36 sized light and won't fit in the wingtips.
You'd be looking for our The Works kit instead.
Thx
Hi Rob.
With around 7-8 amps of current draw and our deliberately low-tech (and therefore noiseless) power regulation used for the LEDs, we specify 14AWG. Ashley had 16AWG already in his wings and I think he's still moderately happy with the outcome!
So, 16 will work but 14 is preferred with a little less voltage drop over the run.
(Two runs of 18AWG in parallel will also work a treat if you have ~100ft spare.)
Paul McVitty
Flyleds.com
VAF advertiser
Old 07-06-2019, 03:29 AM
plehrke's Avatar
plehrke plehrke is offline
You may want to warn others to avert their eyes as you taxi past them.
Philip
RV-6A - 13 years over 900 hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
