Old 05-31-2017, 06:45 AM
Salter Salter is offline
Default ????????
Anyone have any ideas?
RV-14 SN 140398
emp & wings complete
fuselage in progress
N70C reserved
Flying out of 82J
Old 05-31-2017, 06:52 AM
Mel's Avatar
Mel Mel is offline
The RV-11 is a motorglider. Will most likely never see production as a kit.
A&P/BGI/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 05-31-2017, 05:59 PM
rvbuilder2002's Avatar
If you are interested in more info, change the setting at the bottom (after you first click on the RV-11 forum) at the bottom to show threads from the beginning (instead of just the past month).
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 06-01-2017, 08:56 PM
Thanks guys!!!!
RV-14 SN 140398
N70C reserved
Flying out of 82J
Old 07-10-2017, 11:52 AM
smokyray's Avatar
smokyray smokyray is offline
Default RV5
Originally Posted by Salter View Post
Thanks guys!!!!
Chris,
Many years ago (when building RV's required you to drill alot more holes) I flew my RV4 to the annual RV fly-in in North Plains (old factory location, Van's backyard) Van took a couple of us over to his garage/hangar and in the rafters was a small airplane not unlike my Sonerai 2. I asked what is was and Van said "The RV5". It was Van's answer to a low cost, VW powered RV anybody could afford. It too, never went into production as a kit.
My guess is Van's sport-plane marketplace savvy (as Mel so intuitively pointed out), ruled out production for the same reason as the RV11. Not enough demand.
The Xenos motorglider kit however by Sonex is probably the closest thing to the RV11 vision out there...
http://www.sonexaircraft.com/aircraft/xenos.html
V/R
Smokey
On a another cool note, my RV4 turns 20 this week...
Old 07-10-2017, 12:02 PM
As I recall, the 11 was to use a Rotax engine, and a set of production glider wings......you built the fuse and tail.
Old 07-10-2017, 12:37 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by smokyray View Post
Chris,
Since you brought up the RV-5......
https://newsline.kitplanes.com/2017/...ecret-project/
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-10-2017, 01:01 PM
DaleB's Avatar
DaleB DaleB is offline
Why do I think that trip had more to do with the suspiciously engine-less RV-12 sitting behind it? I'll pretend I didn't see the 3-blade prop hanging on the wall.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 07-11-2017, 07:49 AM
smokyray's Avatar
Default Five is enough...
Awesome Paul, I'll look forward to the article...
V/R
Smokey
PS:I guess DR will have to add another "RV type" to his thread list!
Old 07-13-2017, 08:43 AM
Chris,
V/R
Smokey
The RV-5 was never designed to be put into production as a for sale kit.
In fact (from my understanding) the drawings were never much beyond napkin sketches.
It was designed to be a flight test platform for a 1/2 VW engine that an acquaintance of Van was working on. The build of the airplane was taken on as a EAA Chapter project, with Van consulting.
The 1/2 VW proved to be not viable (lower than expected power and rather rough, from what I have heard).
Rather than just discard the airplane it was re-engined with a 447 Rotax. From what I have been told it was an amazing performer in that configuration.... even though it is only 40 HP performance can be impressive with an airplane empty weight of under 350 lbs.
Van's niece and nephew (brother Jerry's son and daughter) put a lot of hours on it building time for their commercial tickets.
It will hopefully fly again if we can find all of the parts needed to refurb the engine (rather scarce now adays).
Scott McDaniels
Hubbard, Oregon
