Old 03-18-2015, 11:23 PM
Arvey Fleur's Avatar
Arvey Fleur Arvey Fleur is offline
Default RV-8 rear cabin heat diverter manifold
The RV8 cabin can be too hot in the front and too cold in the back.
I made this low profile manifold that will fit behind the brake pedals at full extension. 1 1/4 scat tube sends the air back to vents beside the front seat to blow directly on the back seaters feet! It works great. I also warm my hands with it.
The manifold has a bare-toe-operated door, I usually keep it closed, could prolly eliminate it. The heater valve is still there on the engine side, but I did have to trim down the short valve outlet pipe flush with the firewall.
Cheers!
http://dan.bobbob.net/heater.dxf
DanR
RV8
"Life seems so much simpler when you're fixing things." - Anakin Skywalker
Dues Paid 2019
Old 03-18-2015, 11:32 PM
jjhoneck jjhoneck is offline
That's really great. Our back cockpit is COLD!
Jay Honeck
RV-8A N14EG
Port Aransas, TX
Old 03-18-2015, 11:36 PM
Default Sheet metal template drawing
Here's a pattern template case anyone wants to make one.
DanR
RV8
Dues Paid 2019
Old 03-19-2015, 12:27 PM
SHIPCHIEF SHIPCHIEF is offline
WOW;
I surrendered to providing blanket, electric jacket liner, leather flight helmet, ski gloves, scarf, snowmobile suit....
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 03-19-2015, 01:24 PM
RVTOY RVTOY is offline
Default Look at picture #1
It may just be the picture but it does appear there is air in the clear brake line. George
RVTOY
RV7A - N11RV
Kitfox 7 completed 2009. Lost in 2010 KJOA Flood. New Airworthiness cert. 6/8/2018
Always an upgrade in progress.
Donated to keep forum alive.
Old 03-19-2015, 03:39 PM
mike newall's Avatar
Heated seats, front and rear ;-)
Donated in 2019
Old 03-22-2015, 08:11 PM
Default Needs more heat
Yes! Heated seats are awesome!! I also have electric heated seats front and rear. And 2 heat muffs plumbed in series. Now I have LOTS of heat!!
But before that I had only one heat muff dumping air thru the firewall at my toes. One spring trip I took off from a warm Idaho Falls on a 4 hour flight over the Sierra into the setting sun. At altitude, I lost the warm air and the solar heating, and it became REALLY COLD. Combined with the thin air at high altitude it was just miserable. I think if I would have had a rear passenger on that flight they would have become a human popsicle.
I do carry warm clothes in the plane for emergencies, but I don't want to wear them all or be fussing with adding/removing layers in flight. The heating flexibility is nice to have!
Cheers!
DanR
RV8
Dues Paid 2019
