Old 05-28-2018, 10:47 PM
Robb Robb is offline
Default RV7 Rudder
My RV flies fine except the ball is about 1/2 out of the cage. I have to fly with constant right rudder to keep it straight. Its not a big deal but on long flights my leg gets tired. My Husky has a trim tab to correct the problem and the RV does not. Whats the best way to deal with it ? I don't want to add a trim tab as it will look like ****.
Old 05-29-2018, 12:23 AM
arffguy arffguy is offline
Most RVs have a trim tab. Nobody is going to care except you. Some guys have added a trim system to the rudder cable (I don't know the details), others have made a moveable tab with a servo to move it. Do you happen to know Keith at Grass Valley? Maybe he can help. Good luck.
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid in Feb anyway
Old 05-29-2018, 05:33 AM
BillL BillL is offline
Default Gear Fairing Alignment is really sensitive!
I am no expert, but now 18 hrs into Phase I and have been fiddling with the same. I jacked the plane and rechecked all the alignments, wheel pants, gear fairings. I tweaked the gear fairings maybe a 1/32" and the pants were within 1/16" One pant was rotated about it's axle 2 degrees (a lot). It did make a difference, a significant improvement, but still off a tick in cruise. 1/2 ball (G3X) would take two feet on the rudder to correct at 150 kts, so that is a lot.
Full disclosure, I also am progressing with a heavy wing correction, and moved 3 of 4 of the aileron hinges at the same time. I must have neutralized the changes as it still had about the same left heavy, so I don't think it had anything to do with the rudder issue.
In a dark hangar I might just tweak the gear fairings another 1/32" on the TE to avoid a rudder wedge.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 05-29-2018, 06:43 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
The manufactured plastic trim tabs painted to match and installled with professional double faced tape is not bad looking.
Trim tabs are very common on RV's.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 05-29-2018, 06:59 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
The hanger gremlins must of have visited my hanger in the past year. I've been flying my -7 for over 4 years now and the first 3 years I flew it, there was no need for rudder correction in cruise. Over the past year or so I can definitely see a need for about a 1/4 ball of R Rudder. It's very strange.
Amir
RV-7 QB - N174WM
Supporting VAF since the first visit
Old 05-29-2018, 07:35 AM
Jpm757 Jpm757 is offline
I had the same problem on my -6. I installed rudder return springs on both my -7 and -6 mainly to keep the slack out of the cables. I found that on my -6 that if I used a slightly tighter spring on the right rudder cable it would compensate for the need for right rudder in cruise, sort of a rudder trim. Served the same purpose as an external tab, worked great.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 200+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
KOXC Oxford, CT
1941 J3 Cub skis,floats.
2019 dues gladly paid.
Old 05-29-2018, 09:16 AM
Vern's Avatar
Vern Vern is offline
Default Rudder tab
Clear silicone will attach a modest tab on your rudder and it can be easily removed.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 05-29-2018, 11:16 AM
Timberwolf Timberwolf is offline
Be careful with silicone and aluminum. Acetic acid is released on some types while curing which can lead to corrosion. Easiest way to identify is if it smells like vinegar, don't use it.
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P in progress
Aero Engineer, A&P
Old 05-29-2018, 12:04 PM
Raymo's Avatar
Raymo Raymo is offline
Mine was the same. I simply used my hands to tweak the rudder trailing edge very slightly. Took a couple iterations (went too far at first) but it now flies straight in cruise and requires less right rudder in climb. You would not know by looking at it that I did anything.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 05-31-2018, 08:12 PM
Thanks for the info
