Old 05-26-2018, 02:09 PM
Vansconvert Vansconvert is offline
Default Tire pressure
What are running for tire pressures on A models, mostly hard surface runways?
RV-7A
IO-360 Hartzell CSP
Purchased
Old 05-26-2018, 02:30 PM
jdiehl jdiehl is offline
Default Tire pressure 7A
45 psi on the nose and mains seems to work well with never a flat- nearly always on pavement. Just one short period of minor shake on the mains at perhaps 15-20 mph on rollout.
Jim Diehl 7A
Old 05-26-2018, 05:23 PM
YellowJacket RV9 YellowJacket RV9 is online now
Jim Diehl 7A
Seconded. I run 45 all around with absolutely no issues.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 05-26-2018, 09:15 PM
Bevan Bevan is offline
I found my main gear shimmied when tire pressure was over 35lbs. I keep them between 25-30lb and no more shimmy.
Nose wheel 35 lb.
I should add, my main tires are 380x150x5 and nose tire is 500x5. (Bigger than usual) That may account for needing lower pressures.
Bevan
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 05-27-2018, 12:04 AM
bruceh's Avatar
bruceh bruceh is offline
Anywhere between 40-45 psi has worked fine for me on nearly 100% of landings done on paved runways. I check the inflation every 3 months and usually have to add a few pounds.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 05-28-2018, 06:43 PM
flytoboat's Avatar
flytoboat flytoboat is offline
Desser advised never less than 50psi on mains (RV6A).
Don
VAF #1100, EAA864
-6A bought flying
Old 05-28-2018, 06:53 PM
flysrv10 flysrv10 is offline
go here at Dresser web site for tire pressure chart: https://www.desser.com/content/pressure_chart.asp
Old 05-28-2018, 07:59 PM
You likely notice in Desser's chart that it is a one pressure for all aircraft, recommendation. Not very practical considering aircraft using the listed tires have a wide range of max. gross weights. (in fact they say refer to owners manual for factory recommendations).
The question was rather generic, just asking about "A" models, I would only recommend 50 PSI for an RV-14A (gross weight of 2050)
Scott McDaniels
Hubbard, Oregon
Old 05-29-2018, 08:29 AM
I should have been more specific, it's a 7A.
RV-7A
IO-360 Hartzell CSP
Purchased
Old 05-29-2018, 12:34 PM
alcladrv alcladrv is offline
I'm 95% on pavement in my -7A. I've used 50 psi in main tires and 40 psi in nose tire for several years without any issues. Nose tire is checked monthly and mains every other month. Michelin tubes on the mains hold air much better than the Leakguard tubes I used previously.
