Old 01-30-2020, 02:33 PM
bobg56 bobg56 is offline
Default Trailers for RV12
I have a question regarding trailers, since I have to keep my RV12 out on the ramp (hanger waiting list), I'll need to get it home to my garage so I can do the newest SB for NLG., fortunately I'm only 5 miles from airport. I have removed wheel pants and measured 82.5" outside to outside of main tires...all of the 7' wide trailers I've seen are only 81.5" wide. I have a welder and have thought about getting a Harbor Freight trailer and modifying it and putting 10" or 12" tires on it, this is the way it looks like I'm heading...I'd like to know if any of you have come up with a trailering solution. If they actually made the trailers 7' wide (84") it wouldn't be much of a problem except for making a wing rack....Thanks, Bob
Old 01-30-2020, 05:56 PM
Piper J3 Piper J3 is online now
You might be able to store your wings in someone's hanger. Wings don't take up much room...
Hinckley, Ohio (1OA2)
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 524
LSRM-A Certificate 2016 for RV-12 N633CM
Old 01-30-2020, 09:49 PM
rolick22's Avatar
rolick22 rolick22 is offline
Default Trailer
I rented a trailer from Cat rental it was 81 inchs wide. worked great.
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Need:
Finishing Phase I
Paint?
Serial#12-0864
N112DR
VAF donation made for 2020
Old 01-31-2020, 06:48 AM
Those are the kind of trailers I was looking at, I'm thinking that with wings off the load is reduced on main gear so that 81" of width is good...I put a board against the outboard edge of my main wheels and measured 82.5"...thanks for the picture.
