Old 10-25-2018, 02:55 AM
dbhill916 dbhill916 is offline
Originally Posted by tomkk View Post
I don't like lifting the 5 gallon cans up to the tank opening so I got a Flo-Fast pump and one of their 5 gallon cans. The pump has a grounding cable that I attach to the aircraft. I transfer the fuel through a Mr. Funnel into the pump can then use the pump to get it up into the tank. Works well and is pretty easy.
+1 Flo-Fast system
David B. Hill
N76012
RV-12 #0760
http://n76012.blogspot.com
Dues paid through 6-2020
Old 10-25-2018, 04:59 AM
Originally Posted by rv7charlie View Post
The biggest downside I've seen is that if fuel sits in the carb's fuel bowl (small volume, high surface area) for more than a few weeks, the engine will be very hard to start. Since auto fuel has 'aeromatics' (?) that enhance starting ability, my totally unqualified opinion is that those components flash off a lot more quickly than the rest of the chemicals in the gas.
I never thought about that, but the Rotax has a leg up here. Consider this scenario… airplane is done flying and put away hot, which is pretty much always the case. Latent heat under the cowl heat-soaks the carbs until the engine returns to ambient temp. So the fuel may well volatilize in the carb bowls and vent the fuel vapor out the overflow tubes. No problem, and in fact, a good situation. Now, when the airplane is powered for next flight, the electric Facet fuel pump will recirculate and deliver fresh fuel (with correct octane) to the near empty float bowls. Always an easy engine start with no detonation from deteriorated fuel.
Hinckley, Ohio (1OA2)
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 526
LSRM-A Certificate 2016 for RV-12 N633CM
Old 10-25-2018, 06:03 AM
strahler13's Avatar
strahler13 strahler13 is offline
Here's a shot of our Flo Fast set up. Use to fill the Rans S-7. Works very nicely.
Mark Strahler
RV-6 (Purchased flying)
KFFC-Peachtree City, GA
Old 10-25-2018, 06:54 AM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Here is my Flo-Fast in action. Don’t know how many turns per gallon but it only takes a few mins to fill the tank. Easy Peasy
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 10-25-2018, 09:46 AM
tomkk's Avatar
tomkk tomkk is offline
Originally Posted by jwyatt View Post
How long does it take to turn those 10 rotations and pump the gallon? I picked up a few 10 gal FloFast jugs on sale, now trying to decide between the hand pump or a DC pump rig on a cart.
I don't know, maybe 5 or 6 seconds. 1/2 minute or so for 5 gallons. It's not strenuous either, it's a pretty easy pump.
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 10-25-2018, 10:06 AM
Just out of curiosity, what's the pump body material? Functionally, it looks very similar to
https://www.harborfreight.com/dual-d...ump-40844.html
which says 'not for gasoline', but that's their lawyers talking. One of those worked great to transfer avgas from our airpark tank to our generators during the aftermath of Katrina. Worst thing for portable use is that it's cast iron and not light.
Old 10-25-2018, 10:26 AM
I’ve only experienced one issue with “old fuel”. I let a tank sit for 4 weeks during a long summer vacation and when I flew I experienced some pressure surges due to vapor bubbles in the fuel line. When I switched on the electric pump the fuel pressure stabilized. Usually my fuel pressure is fine with just the mechanical pump.
Old 10-25-2018, 11:06 AM
Dave12 Dave12 is offline
I counted 65 turns for five gallons.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 10-25-2018, 11:30 AM
tomkk's Avatar
Not sure. The body is not metal so some sort of plastic with a metal handle. The Professional model seems durable enough. As I said earlier, I had problems with the Premium model leaking through the O-rings on the handle shaft.
That HF pump is a barrel pump and, as far as I know, won't fit any gas can I know of. Of course, if you have a barrel ...
The Pro model is a 3 vane pump vs 2 vane with the Premium model so it pumps faster.
Tom
Port Orange, Fl
EAA #51411
Old 10-25-2018, 01:24 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Default Ground while refueling
I also use the Flo-Fast Pro pump. It comes with a static ground wire attached and I use it. The pump static wire gets attached to the tail tie-down. I also have an aircraft ground cable attached to the tie-down which attaches to the hangar ground.
You can't be too safe refueling with gasoline, ya know
Tony
E-LSA RV-12 ULS
