Old 04-18-2019, 03:53 PM
Noah's Avatar
Noah Noah is offline
Default Swapping ADS-B transmitter between 2 aircraft
I need to equip 2 aircraft with ADS-B out. One of them is my RV, and the other, a manned hydrogen balloon, is only flown once or twice per year. I'm thinking of having compliant position sources, antennae, transponders, and harnesses in each aircraft, and simply moving the ADS-B unit itself. This should be pretty simple if I locate it someplace accessible.
Any gotchas to this plan I haven't thought of?
I'm currently leaning toward the uAvionix Echo, simply due to cost. Registration, aircraft type, and other settings are easily reconfigured via wireless connection to a tablet, so the thinking would be that I would have a list of settings to change when moving between aircraft. Position would come from a GNS430W in the RV, and a SkyFYX in the balloon. Each aircraft already has a Garmin transponder. Might not be able to do international flights with 978 MHz UAT transmitter. Planning to port data to AFS4500.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men… for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 04-18-2019, 04:06 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Not required in the balloon?
I know aircraft without engine-driven electrical systems are exempt --- why does the balloon require it?
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 04-18-2019, 04:13 PM
Noah's Avatar
Great question! These flights are hundreds to thousands of miles and go for multiple days through / over all kinds of airspace. So primarily need it so I don't splat on the windshield of an airliner some dark night while my copilot is flying and I'm sleeping.
Highest Regards,
Noah F, RV-7A
Old 04-19-2019, 08:44 AM
RONSIM's Avatar
Smile Great reason!
Had not thought about that scenario!
Old 04-19-2019, 09:13 AM
Raymo's Avatar
Raymo Raymo is offline
I know this can't be done with GA aircraft because it requires a 337 with I/A sign-off after installation. If proper transponder/ADS-B ground test equipment is not available, another 337 is required to prove it passed the FAA validation during a post installation operational flight evaluation (OFE). I supposed you could move the equipment, in this case, and re-do the paperwork each time.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 04-19-2019, 09:20 AM
Noah's Avatar
Both aircraft are experimental, does that apply here?
Highest Regards,
Noah F, RV-7A
Old 04-19-2019, 09:31 AM
Raymo's Avatar
The 337 does not apply to EAB. I don't know what the regs say around moving equipment but I would think the FAA expects it to be a permanent installation. You'd certainly have to update the tail number and ICAO hex code with every swap, but that isn't difficult.
Ray
Old 04-19-2019, 05:38 PM
pjc's Avatar
pjc pjc is online now
That’s a very good reason!
RV6 N42HC flying
2019 Dues paid
Old 04-19-2019, 07:52 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
Noah,
That should work as the echo UAT transceiver is a standalone unit. You can easily mount it on the same ground plane as the UAT antenna in the balloon. It should be easily ported to either aircraft. I recently installed the same unit on the inboard wing inspection panel.
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Pmags, CS
Bridgewater, MA
KPYM
Old 04-19-2019, 08:00 PM
TimO TimO is offline
I'm not sure how high you fly the balloon, but in the flight levels, 978Mhz UATs aren't legal ADS-B systems. For the flight levels you'll want a 1090Mhz system.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1400+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 350+ hours http://www.MyRV14.com
