Old 04-04-2019, 04:14 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default ADSB GPS for IFR flight
Maybe this has been discussed here before, but I don't recall reading anything about it, but I'm wondering if the new WAAS GPS units being sold by Dynon and UAvionics and such for ADSB can be used for legal IFR navigation?
I'm guessing that the answer is no, because they are not a part of a "certified" GPS "navigator", but it seems to me that if they are accurate enough for ADSB that maybe they are for IFR. No? Again, probably a different certification standard but I'm just wondering.
I also understand that the moving map and control function of any of the EFIS systems (other than the certified Dynon and Garmin units) are also not certified for IFR use, but hey? Just curious.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 04-04-2019, 04:39 PM
sglynn's Avatar
sglynn sglynn is offline
Default ADS-B for IFR
If your ADS-B out solution is legal for VFR it is legal for IFR.
My RV-7A has Dynon's ADS-B In and Out and I plan to fly it IFR.
And I'm putting the uAvionics on my Piper Cherokee and it is an IFR platform.
Only ADS-B out units not legal for IFR are also not legal for VFR and they are the dash board (not installed) solutions, but I can't even think of one anymore.
There is no requirement for ADS-B In. And this is currently only a USA requirement.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 04-04-2019, 05:28 PM
rolivi's Avatar
rolivi rolivi is offline
I'm gonna jump out with NO straight out of the gate.
A WAAS position indicating unit is ONLY good for the ADS-B mandate.
ADS-B out only, such as 330ES, is perfectly legal in rules airspace with a compliant position source, like a 430W.
Your navigator must be IFR certified, and need not be WAAS.
Two uses of similar technology.
Rob
RV-6A (Purchased)
2019 Dues Paid, of course
Old 04-04-2019, 05:58 PM
Veetail88's Avatar
I always thought that the 430non-WAAS navigator was not certified or IFR flight, but the WAAS version is.
Either way, I suspect you’re correct about the WAAS GPS ADSB receivers not usable as a certified source receivers for IFR flight, but I would think if they meet standards to keep airplanes from crashing into each other that they should be accurate enough to fly IFR with. Coupled with an EFIS for display of course; at least in E/AB aircraft.
Jesse Bentley
Old 04-04-2019, 06:35 PM
Auburntsts's Avatar
There’s a lot more that goes into IFR certification than just GPS position accuracy, particularly on error detection and correction, but there are other differences too. Also the non-WAAS 430/530 is IFR certified but limited to enroute nav and basic LNAV approaches. Also it can’t be used for sole source nav and there’s more restrictive alternate selection criteria than for a WAAS box.
Todd “I drink and know things” Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-05-2019, 12:00 AM
BobTurner BobTurner is online now
In addition to the gps, the TSO has a lot of requirements on the database. For example, approaches must be in the database - the pilot may not enter lat-long by hand. None of the new GPS boxes designed for ADSB have a database containing approaches, so using one will require ‘marrying it’ to a database.
Old 04-05-2019, 08:11 AM
MercFE MercFE is offline
The non-WAAS GPS is IFR legal... Just not as a sole source, it requires a VOR or other nav source as well. Therefore, the 430 is legal as it has both sources in one unit.
Old 04-05-2019, 09:21 AM
We need to pay a little closer attention to terminology, because the devil is in the details of this terminology.
That little GPS device that feeds position to your EFIS and/or your ADSB-Out device is what is referred to as a GPS SENSOR.
The panel mount 430 or similar is referred to as a GPS NAVIGATOR.
There's a world of difference between a Sensor and a Navigator.
A Sensor provides position/rate/time information to other systems.
A Navigator often contains a Sensor, and uses its position/rate/time information in combination with a navigation database to produce a flight guidance solution to allow us to navigate between pre-defined points contained in the database.
The IFR question is really easy to answer... Since a SENSOR doesn't have an approved IFR database, it cannot be used for IFR navigation. If another device in the aircraft has an approved IFR navigation database and uses the SENSOR data, then it may be capable of IFR navigation - this is a common configuration in transport-category aircraft where the GPS sensor feeds its data to a Flight Management System. There is another current thread here on VAF discussing this topic, specific to GRT's plan to use its WAAS GPS Sensor along with a database in its EFIS to produce IFR navigation capability. It would do so on a demonstrated capability basis, not on the basis of having been certified as a TSO-compliant GPS navigator. There is some reasonable debate as to the legality of doing this and the probability of success doing this.
So, coming back to the original question... the answer is a simple NO - your ADSB position source, if it is solely a GPS sensor, is not capable of being used for IFR navigation. Unless you have an FMS or similar approved IFR navigation device to which that sensor feeds its data, again the answer is likely a simple no. If you want to use your EFIS as an IFR navigator using GPS sensor input, it's on you to demonstrate that your solution meets the minimum operational performance specs of the equivalent GPS navigator TSO, be that TSO 126 or TSO 145.
Old 04-05-2019, 10:01 AM
sglynn's Avatar
Default gps ifr
So for example
I installed Dynon's GPS sensor (antenna) that has WAAS and it feeds position to the transponder for ADS-B out and that is legal ADS-B out for IFR flights. But that senors (antenna's) position is also fed to the Dynon EFIS which does have maps, but is not TSOed so it is not legal for IFR /G. So I also installed a Garmin 430. It has a separate antenna and that unit makes flying IFR /G legal. I can also drive the Dynon EFIS with the Garmin 430 GPS position and that is legal IFR and I can use the approach plates in the Dynon EFIS for plates, but the 430 is doing to the work, not the Dynon sensor. Do they match yes. Could I practically use just Dynon yes, but not legal.
However, now I see Dynon is getting their HDX box legal to install into Production Planes like Beech V35. I wonder if that will make the GPS side of Dynon's system legal for IFR /G?
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
Old 04-05-2019, 10:26 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Originally Posted by sglynn View Post
So for example
Again the answer is no. There is a whole lot more than having maps to be a GPS navigator. The difference in requirements and certification between a simple GPS position source and GPS navigator is huge ($$$$) and something no experimental company can afford.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2019 Dues Paid
www.PuertoRicoFlyer.com
