Old 08-03-2017, 10:07 AM
JimMac JimMac is offline
Question Gear leg braided brake line
The braided brake line on my RV-12 seems very tight where it has to bend a little to connect to the caliper fitting. The brake line is so stiff and wedged in so tight between the trailing edge of the gear leg and the caliper fitting that it seems that it would impede the caliper from moving on the pins. Has anyone else had any problem with this? I have had to replace my worn-down brake shoes after only 82 hours of use. My right brake pad was dragging and always trying to turn right (at about the 70 hour point). Would it cause harm if I tried to put a permanent bend in the brake line just above the fitting that attaches to the caliper to relieve the "wedged-in" effect?
Jim McCarter
Madison, AL
RV-12 N864RV 90 hrs TT
Donation Made for 2018
Old 08-03-2017, 11:08 AM
DHeal DHeal is offline
Be sure that there is no physical interference between the aft end of the inboard wheel pant attachment bracket and the aft-inboard corner of the brake caliper. If there is such interference, the brake caliper/linings may not wear evenly.
Also, be sure that your caliper guide pins are clean and free to move (albeit somewhat stiffly). MATCO suggests that no lubricant be used on these pins to avoid attracting grit. I typically clean the pins and sparingly apply a touch of "dry" lubricant (e.g., Boeshield, graphite, silicone, etc.).
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 725+ hours (as of Jan 2019)!
VAF donation through June 2019.
Old 08-03-2017, 11:36 AM
Wont help resolve your problem but just a general comment...
A standard build RV-12 doesn't have braided hose brake lines.
Scott McDaniels
Hubbard, Oregon
Old 08-03-2017, 12:43 PM
Jim do you have sufficient slack in the hose at the caliper for the caliper to move freely?
Tom
Ridgeland, SC
Old 08-03-2017, 12:55 PM
Also, do not install gear leg bottom tie-wrap too close to the caliper. Bottom of braided hose needs to float. I'll take photo of my installation next time I fly.
Hinckley, Ohio
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 409
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 08-03-2017, 02:27 PM
Default Gear leg braided brake line
Thanks for the responses, David, There is no interference between the wheel pant attach bracket and the caliper. Scott, I realize the standard RV-12 has the aluminum tube with the loop, but the builder of this plane (who I bought it from) had put these lines from TS-FlightLines on. These look like high quality lines but I may fabricate the aluminum lines with the loop and put those on. Jim S., I would be interested in seeing a photo of yours. Like I said in my initial post, The problem seems to be in how the tube was wedged between the trailing flat surface of the gear leg and the caliper attachment. The brake line is simply not going to be allowed to move as the caliper tries to move. Tom from TS FlightLines, No, there doesn't seem to be enough slack. It seems like this braided brake line might work better if it made a loop around the gear like the original design so that it would exert no resistence to the caliper movement. Well, I think I'll put the aluminum lines on as per the original design.
Jim McCarter
Madison, AL
Old 08-03-2017, 03:03 PM
I will send pic next time I'm at the plane. Mine pretty much looks like the photos in the installation instructions here http://www.aircraftspecialty.com/PDF...201-4-2014.pdf
Hinckley, Ohio
EAA #499867
