Old 12-05-2016, 11:45 AM
scorwin scorwin is offline
Default Rear seat side vent
Got a ? for everyone regarding the rear seat side vents. Mine are pretty difficult to open. Is that typical?
While I don't want them opening/closing at any small gust of wind, should they move freely or only with force?
Shawn
Old 12-05-2016, 12:13 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Some effort - yes. I never put a handle on mine as I did not see the need, but others have.
Old 12-06-2016, 12:20 PM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Mine are just right. Easy enough for my toddler to open, but sticky enough that they don't blow open on their own. I do have the handle extensions on them as part of the Aerosport interior panel set.
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 12-06-2016, 12:57 PM
kmorris kmorris is offline
Loosen the nut slightly. Its a feel thing.
Old 11-13-2017, 09:26 AM
jwilbur jwilbur is offline
Default 3D Print?
Anybody have, maybe, a 3D print solution for the RV10 rear side vents? I'm thinking maybe something like what Aerosport has but without the whole panel.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 11-13-2017, 07:19 PM
Plummit's Avatar
Plummit Plummit is offline
Mine are fixed closed. The NACA vents feeding the overhead console provides all the cool air needed.
-Marc
N814RV
2018 Donation made!
Old 11-26-2017, 09:12 AM
az_gila's Avatar
az_gila az_gila is online now
Question On the ground
-Marc
Just a question from hot AZ.
I'm planning the same OH vent setup... do the vents provide reasonable airflow on the ground while taxying?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-26-2017, 02:38 PM
Michael Wellenzohn's Avatar
Michael Wellenzohn Michael Wellenzohn is offline
Itís something to figure out. I didnít tighten the nur enough at speeds 170 kt + . Itís hard to tighten if you have the aerosportproducts console.
Mike
RV-10 builder (flying)
#40511
Switzerland
Oshí18 OWW volunteer
Countries HB-YNN has visited:
🇨🇭 Switzerland, 🇩🇪 Germany, 🇦🇹 Austria, 🇮🇹 Italy, 🇭🇷 Croatia, 🇫🇷 France, 🇪🇸 Spain, 🇵🇹 Portugal, 🇸🇮 Slovenia, 🇭🇺 Hungary, 🇷🇴 Romania, 🇷🇸 Serbia
www.wellenzohn.net
First flight Video: https://youtu.be/X7EQ81C3xSA
Old 11-26-2017, 08:17 PM
Plummit's Avatar
They do provide air while taxiing, but it's not the same as in flight (obviously). In AZ I would be using my ice-chest air conditioner a whole lot more.
Our son lives in Surprise, and it get too darn hot there during the summer months.
-Marc
N814RV
2018 Donation made!
Old 11-27-2017, 02:04 AM
GregMac GregMac is offline
As said “it’s a feel thing as far as tightness goes, trial and error” a little Armorall on the nylon washers make them slide nice as well. I’ve found they are Easy to push out but a little harder to close, drill a hole and install a good quality key ring for pull closing. They work well when taxying on the ground, and I like to make use of them combined with open front vents to provide air circulation when the aircraft is parked.
