Old 02-02-2017, 12:39 PM
togaflyer togaflyer is offline
Default W&B with Earth X battery
The Earth X shaves around 21 lbs off compared to the Odyssey battery. That is a significant weight change at the battery station. Up front I have an IO 540 with mags, MT prop, and a Plane Power backup alternator. How does this impact the CG of the -10. Will the plane have a significant forward CG. Will I need to keep some weight in the baggage area to compensate for forward CG.
Old 02-02-2017, 01:47 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is online now
Possibly. I have two Earth X batteries on the firewall and a lightweight prop. I've purposely kept the plane light with a forward CG. I keep two 25lb shot bags in the baggage compartment when lightly loaded so I can trim on final. I consider this the best case scenario. With a more aft CG I wouldn't be able to fill the airplane without getting the CG too far aft. This way I move two small canvas bags and can carry over 1100 lbs!
Some people call the 10 nose heavy--I believe that's the design intent to allow the plane to carry a load when required. Vans keeps shot bags in theirs for demo flights too.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 02-02-2017, 02:26 PM
Paddy's Avatar
Paddy Paddy is offline
Thumbs up EarthX Battery
I too have dual alternators and mags but with the heavier Hartzell prop. With a remote transponder and dual batteries/contactors behind the baggage bulkhead and I was worried about shifting the CG too far back, so I switched out a PC-925 for an ETX-900. I calculated that those 21 lbs at an arm of 183.5" was worth almost an inch in empty CG placement. Result is that I need ballast when solo, but can load to max gross comfortably without worrying about getting the CG too far aft, even with minimum fuel. My plane feels very similar in balance to the factory -10 in which I did my transition training with Mike Seager, who also used ballast in the baggage area during training. That EarthX battery spins the IO540 like a car and with the Slickstart module, it fires up within a few blades both cold and even after a hot soak.
Flying as of 10/30/16 after 8 yrs building
Old 02-02-2017, 02:52 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Rich,
As an example, I just calculated my new CG assuming that I used two earth-x batteries in place of the two odyssey batteries I have now. (Both of my batteries are located directly behind the baggage bulkhead.) This would yield a weight reduction of 32.6 lbs. The Vans specification for the forward CG limit is 107.8. ( I have a Hartzell prop)
Currently the CG with 15 gallons of fuel (min reserve for me) the CG is 108.3, and with pilot only @180lbs, the CG moves to 108.9.
With two Earth-x batteries and 15 gallons of fuel, the CG goes to 107.4, and with one 180lb pilot is moves to 108.1.
Hope this helps your thought process...
Bill Peyton
RV-10 - 780 Hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 02-02-2017, 05:23 PM
Super Moderator
My RV-10 has an MT 3 blade prop and an Earthx 1200 battery.
I also have tip tanks. I fly a lot solo, with full tanks, including the tips, and the usually 10 lbs of "stuff" in the baggage compartment. I never feel a need to add ballast. It lands very nicely and never runs out of trim for landing.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 11-27-2017, 09:15 AM
Bill Boyd's Avatar
Vic
Vic - EarthX 1200 on the firewall or in the plans location?
Is there room on the firewall for an Odyssey 680 if I use the f/w mounted oil cooler and a spin-on filter, either remote or engine-mounted?
What else might get in the way of a battery there - a vacuum pad backup alternator?
Trying to plan (way) ahead and wanting to run the empty CG pretty far forward and keep the basic empty weight down as well...
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 02-03-2017, 06:46 AM
majuro15's Avatar
majuro15 majuro15 is offline
Guy, do you have any pictures or details on mounting the dual batteries on the firewall? I'm curious and couldn't find any on your build log.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Fuselage under construction
N1017H Reserved
EAA #: 1106970
2018 VAF Dues Paid!
Old 02-03-2017, 04:37 PM
Apparently I don't. I'll take some next oil change. I have both batteries near the right side of the firewall with the contactors just to the right of them.
Guy Prevost
Albuquerque, NM
Old 02-10-2017, 09:42 AM
ppilotmike's Avatar
I'd like some pictures too. How are they holding up in the engine compartment. I would think the heat would affect things negatively and potentially shorten the life of the batteries..
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/15/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
Old 02-03-2017, 08:59 AM
Strasnuts Strasnuts is offline
I like GUYS setup and if I had to do it again I would go this direction. I have a 925 in the back and a two blade blended hartzell up front. I also have a heavy engine, a dash N1A5. I use half flaps when I'm alone if runway permits. I can go full flaps but use a lot of trim. Mine is on the fwd cg when I'm alone.
A&P RV-10 Flying 950 hours
SuperSTOL Flying 100 hours
