Rudder conversion
You will have to drop your cooling ramp. If yours uses a pin that can be pulled to lower the aft end of the ramp, you will be able to reach up inside and install a couple of nutplates to hold the aft pedal mount. The front mount can be accessed by removing the floor of the forward baggage compartment and the cowling.
